franki Posted September 6, 2021 Share Posted September 6, 2021 Ive replaced the Auto Trans and carried out some engine refresh works. Engine and transmission back in. But now have no start at the key. If i jump the starter relay it works fine. Tried a replacement relay still the same. I have noticed the clock dims when the key is moved to the start position but thats it. There are no alarms or immbolisers fitted. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 6, 2021 Share Posted September 6, 2021 Check you have 12v supply to the relay. Then check ground at relay location is good. Then relay to the starter point but that could be a ball ache due to panel access. If long enough. Check connection from relay to starter motor. Should be one of those. I'd guess all that work though, check earthing points. Quote Link to comment Share on other sites More sharing options...
evinX Posted September 6, 2021 Share Posted September 6, 2021 Any damage to the starter inhibitor wiring on the gearbox? Big grey plug. Check for no damage to the wires. Black wires Quote Link to comment Share on other sites More sharing options...
