Paulie Posted August 26, 2021 Share Posted August 26, 2021 Hi All, I'm back with another thrilling question that I'm hoping a kind soul will have an answer for. I have a blown bulb on the instrument cluster (it seems dark on the upper right hand side of the rev courter / upper left of the fuel gauge. Before I take out the unit I may as well replace all the bulbs back there. As sure as eggs are eggs, if I only replace one bulb, others will ping as soon as I put it back together. Does anyone know the part numbers for the bulbs I might need? Or, are there plug n' play LED versions available? I've seen these advertised and they look like they may do the trick but I've no experience with such things. https://www.ledguys.net/products/toyota-supra-gauge-cluster?variant=15406838382679 Thanks in advance, Paul Link to comment Share on other sites More sharing options...
mattdavies Posted August 26, 2021 Share Posted August 26, 2021 Pretty sure the Cluster bulbs are simply 3 x T10 and 1x T5 push fit wedge bulbs If you have a search you should find this info to confirm what I said. if yo uwish to use LED bulbs then I dont think it will cause any issues 1 Link to comment Share on other sites More sharing options...
Paulie Posted August 26, 2021 Author Share Posted August 26, 2021 10 minutes ago, mattdavies said: Pretty sure the Cluster bulbs are simply 3 x T10 and 1x T5 push fit wedge bulbs If you have a search you should find this info to confirm what I said. if yo uwish to use LED bulbs then I dont think it will cause any issues That's great, thanks Matt, much appreciated. Paul Link to comment Share on other sites More sharing options...
