Private plate question
Bender
Its a simple form and fee to sort that out. The only proviso is the plate has to be older than the vehicle onto which it is assigned. The donor car will then revert back to its original pre private plate registration. I did it from a company vehicle onto my Supra before I sold the company truck.
https://www.nationalnumbers.co.uk/faq/how-transfer-number-plate-vehicle-to-vehicle.htm
https://www.gov.uk/personalised-vehicle-registration-numbers
https://www.gov.uk/government/publications/application-to-transfer-or-retain-a-vehicle-registration-number
Thanks for all the links. Private plate starts with M (its a 95 Supra) and want to transfer to 94 Supra which is M plate too it that will work out?
Should be fine,
On the DVLA site as soon as you remove the private plate you'll get a code which you can put straight on to the new Supra. There are instances where if the vehicle hasn't been taxed, or had a period of being untaxed in the last few years it won't like then you'll have to send it by post.
