baldy Posted August 19, 2021 Share Posted August 19, 2021 The new cast alloy bellhousing is meant to quieten the t56 quite a bit. surely at 1000+hp the exhaust is going to be very loud anyway. All after market Diffs use the stock crown wheel and pinion Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 19, 2021 Share Posted August 19, 2021 6 hours ago, baldy said: The new cast alloy bellhousing is meant to quieten the t56 quite a bit. surely at 1000+hp the exhaust is going to be very loud anyway. All after market Diffs use the stock crown wheel and pinion That’s a really good point Quote Link to comment Share on other sites More sharing options...
Noz Posted August 19, 2021 Share Posted August 19, 2021 7 hours ago, Frank Bullitt said: You either use a 200mm version (small diff) or 220mm version (large diff). You know how a 1.5 way works? Edit 1 way the LSD works under acceleration and is not effective on deceleration. 1.5 way the LSD works under acceleration and is half effective on deceleration. 2 way the LSD is effective under acceleration and on deceleration. Not looked into them no. Thanks for learning me 20mm doesn't seem much. I guess it's a chunk being outer diameter. Thought it was bigger to be fair. Quote Link to comment Share on other sites More sharing options...
Noz Posted August 19, 2021 Share Posted August 19, 2021 6 hours ago, baldy said: The new cast alloy bellhousing is meant to quieten the t56 quite a bit. surely at 1000+hp the exhaust is going to be very loud anyway. All after market Diffs use the stock crown wheel and pinion Mines only 600 and its too loud. Fitting a diverted piece and baffle/cat to mine. Friggin noise stops me wanting to drive anyway late at night. RealStreet recently showed a twin box 5" setup and apparently drives smooth nothing too loud. Quote Link to comment Share on other sites More sharing options...
