Pulleys - condition
SUPRA4EVA
Given what could happen if the belt does go because it gets damaged by the pulley, I would just replace it whilst you have access. It might be a non interference engine but if that belts lets go at speed, it can do all manner of damage to the things around it.
  • Like 1
Agreed, I'd replace the crank pulley, timing belt, aux belt and WP all while you have access for the sake of a few hundred pounds.
The condition of the pulleys on the PS and A/C look fine to me and probably wouldn't be an issue. It's up to you but if you're going through a mini restoration, a new A/C compressor, reconditioned/new PS pump and rebuilt Alternator may also be a smart idea, so you know everything is new/good when it's finished.
