Bender Posted August 4, 2021 Share Posted August 4, 2021 I want to swap geniue Toyota radiu for something more modern. Took everything out and conectors was slighty diffrent than in any other Supra (i guess factory subwoofer fault) try to find ISO lead but its quite hard however i found something (pics in post) but it only have one conn instead of two it that will be ok? Or what should i look for? Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted August 5, 2021 Share Posted August 5, 2021 Hi, i guess you need this: https://www.amazon.com/Wiring-Harness-Adapter-Toyota-Adaptor/dp/B00ZIBBK78 Quote Link to comment Share on other sites More sharing options...
Bender Posted August 5, 2021 Author Share Posted August 5, 2021 40 minutes ago, Wishieftrottle said: Hi, i guess you need this: https://www.amazon.com/Wiring-Harness-Adapter-Toyota-Adaptor/dp/B00ZIBBK78 That one wont fit diffrent pattern and pin numbers Quote Link to comment Share on other sites More sharing options...
m12aak Posted August 5, 2021 Share Posted August 5, 2021 Have you looked at the wiring diagrams to see what the small plug is for? I would assume that the wiring is the same between JDM and US spec cars with the amplifier so the harness you've shown will probably work. I've had a quick look and it looks like the wires match up off that plug R6 (the bigger one) which leads to the amplifier, but wiring is definitely not my strong point, so i'd check yourself too. Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted August 6, 2021 Share Posted August 6, 2021 (edited) 23 hours ago, Bender said: That one wont fit diffrent pattern and pin numbers You are right. But I used this adapter when I put new Sony 2din into my supra 3 years ago. I need to check my photo documentation and I will give you some info. Edited August 6, 2021 by Wishieftrottle (see edit history) Quote Link to comment Share on other sites More sharing options...
Bender Posted August 6, 2021 Author Share Posted August 6, 2021 1 hour ago, Wishieftrottle said: You are right. But I used this adapter when I put new Sony 2din into my supra 3 years ago. I need to check my photo documentation and I will give you some info. Thanks i got Sony 2 din unit too. Will wait for info thanks Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted August 8, 2021 Share Posted August 8, 2021 I found a picture of my radio connectors and I am afraid I cannot help you in this. My connectors looks like this: Quote Link to comment Share on other sites More sharing options...
Bender Posted August 10, 2021 Author Share Posted August 10, 2021 On 8/8/2021 at 7:42 PM, Wishieftrottle said: I found a picture of my radio connectors and I am afraid I cannot help you in this. My connectors looks like this: Thanks for looking anyway on every Supra i got this Type of conectors too and connecting radio wasnt never been a problem. Anyway i got right harness nie connect everything and its not even power up Quote Link to comment Share on other sites More sharing options...
