bradleyh_15 Posted July 16, 2021 Share Posted July 16, 2021 As above has anyone got any tips at removing these as mine won’t budge Quote Link to comment Share on other sites More sharing options...
rider Posted July 16, 2021 Share Posted July 16, 2021 If you are on about the side cushions they are araldite in at the factory so you'll need to cut away the old ones and then heat with preferably a small gas torch the top of the bolt to soften the araldite. Once its soft they come straight out. The bottom cushions aren't glued in so should be easy enough to remove/replace. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 16, 2021 Author Share Posted July 16, 2021 1 hour ago, rider said: If you are on about the side cushions they are araldite in at the factory so you'll need to cut away the old ones and then heat with preferably a small gas torch the top of the bolt to soften the araldite. Once its soft they come straight out. The bottom cushions aren't glued in so should be easy enough to remove/replace. Thanks for that, I mean these Quote Link to comment Share on other sites More sharing options...
rider Posted July 16, 2021 Share Posted July 16, 2021 They are the side ones you need to cut away and then heat to get the bolts out. 1 Quote Link to comment Share on other sites More sharing options...
Annabella Posted July 16, 2021 Share Posted July 16, 2021 As Rider said, but I used a computer air heat gun, that can direct the heat to a very small area, heat the screws and they'll turn, patience is the key. 1 Quote Link to comment Share on other sites More sharing options...
blythmrk Posted July 17, 2021 Share Posted July 17, 2021 I have never heated them but find removing the boot seal gives better access. Quote Link to comment Share on other sites More sharing options...
tayr Posted July 17, 2021 Share Posted July 17, 2021 I think I saw Mike do it with the tool You hammer to turn the screw when they’ve been cross threaded. Cannot remember the name for the life of me Quote Link to comment Share on other sites More sharing options...
Annabella Posted July 17, 2021 Share Posted July 17, 2021 Impact driver. Only problem with that is you can bend the boot sill around the bolt. 1 Quote Link to comment Share on other sites More sharing options...
rider Posted July 18, 2021 Share Posted July 18, 2021 (edited) That's the last thing you want to do when the bolts slide out like they have been freshly oiled after a bit of heat. Edited July 18, 2021 by rider (see edit history) Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 19, 2021 Author Share Posted July 19, 2021 Thanks for all the info guys, heat worked a treat Hardly any heat to and came out so easy. Top knowledge guys Quote Link to comment Share on other sites More sharing options...
