AmitS Posted June 30, 2021 Share Posted June 30, 2021 Is this a common problem with a common cure? From 4th gear it’s very easy to miss 5th as it will go past the point where it slots up into 5th. I remember test driving another tt6 before I bought mine which also did this so I assume I’m not the only one! I have a feeling it didn’t do it before having all the work done (including transmission bush) but either way I want to get it sorted. Just maybe that could help diagnose Quote Link to comment Share on other sites More sharing options...
m12aak Posted June 30, 2021 Share Posted June 30, 2021 There's play my shifter when in gear (I believe all the bushes are original and have 76k miles on them), but I've never had an issue with missing 5th or any other gear. Part of your linkage may be loose (check all the bolts are tight on the tripod etc.) and then go from there. As work has recently been done hopefully it's a simple fix, but from my experience it is not a normal problem. Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 30, 2021 Share Posted June 30, 2021 You are not the first This brought back memories! 1 Quote Link to comment Share on other sites More sharing options...
Paul R Posted June 30, 2021 Share Posted June 30, 2021 2 minutes ago, Scooter said: You are not the first This brought back memories! That was my post. Blast from the past 1 Quote Link to comment Share on other sites More sharing options...
