Burna Posted June 23, 2021 Share Posted June 23, 2021 10 minutes ago, tayr said: My plan was to get the gearbox sorted first then eventually single and ecu.. Do you know if you can run a built autobox on just regular stock ecu/stock tt set up entirely? Of course you can, and that's exactly what you want to do when you do go single and aftermarket ECU. Just make sure you get an ECU that still allows you to retain the stock ECU to control just the gearbox That's exactly what I have done, and Dan has done by the sounds of it. Quote Link to comment Share on other sites More sharing options...
tayr Posted June 23, 2021 Author Share Posted June 23, 2021 (edited) 6 minutes ago, Burna said: Of course you can, and that's exactly what you want to do when you do go single and aftermarket ECU. Just make sure you get an ECU that still allows you to retain the stock ECU to control just the gearbox That's exactly what I have done, and Dan has done by the sounds of it. cool ok - the ATF one threw me off as it says if you're running the AEM ecu it can c*ck it up unless they amend the tuning file. Wondered if these boxes had to have some sort of mapping with them to work correctly Edited June 23, 2021 by tayr (see edit history) Quote Link to comment Share on other sites More sharing options...
Burna Posted June 23, 2021 Share Posted June 23, 2021 1 hour ago, supradanturbo said: Yes stock ecu will control a built gearbox just the same as a stock box. as with all a340 gearboxes. Try not to use wide open throttle in overdrive. And do not wheel spin from 1st into 2nd. Eg a burnout changing into 2nd gear. This is very likely to roll the 2nd gear sprag if you treat the gearbox right. It will last very well. also change the fluid in the sump as often as possible if you are giving it a hard time. Really good advice, and also change the strainer. Quote Link to comment Share on other sites More sharing options...
