** FOR SALE: 1996 Toyota Supra RZ (Facelift PRE-VVTI) 3.0 Twin Turbo (BPU) Auto in 6NO Grey **
r2ck_p
Make: Toyota Supra RZ
Model: 3.0 Twin Turbo (BPU) Auto in 6NO Grey
Year: 1996 (is 25 years old in July 2021 so can be exported to the USA)
Facelift: Yes (Pre-VVTI)
Mileage: 86,879 (odometer reading is all in miles, not a mix of KM/Miles)
Tax Remaining: N/A
MOT Remaining: 12 months - a new MOT will be done prior to sale
Service History: Yes
Car's Location: West Manchester, UK
Price: £30K
HISTORY:
  • V5 says 1 previous keeper since import and registration in Nov 2005
  • I purchased the car from another well respected club member in July 2012
  • 86k miles on the clock (the initial 101,000 km done in Japan were converted to miles on import in 2005)
  • The mileage covered in Japan can be verified by the Motor Vehicle Certificate which is present
MOT HISTORY (ALL MOT Certificates since the car was imported in 2005):
  • 22/11/2005 - 101,416 KM = 63,016 miles
  • 18/11/2006 - 66,072 miles
  • 10/11/2007 - 68,158 miles
  • 01/11/2008 - 70,050 miles
  • 31/10/2009 - 71,981 miles
  • 23/10/2010 - 73,918 miles
  • 29/11/2011 - 74,281 miles
  • 27/10/2012 - 76,852 miles
  • 20/11/2013 - 78,590 miles
  • 29/12/2014 - 80,524 miles
  • 05/12/2015 - 81,893 miles
  • 30/12/2016 - 86,388 miles
  • The car has been SORN and garage stored from 30/12/2017 onwards to preserve its condition. A new MOT will be provided prior to sale.
SERVICE HISTORY (UK):
  • 22/11/2005    101,000 kilometres#
  • 08/12/2005    New tyres
  • 01/01/2006    64,000 miles. Cam belt, one set of plugs, Toyota engine mounts, 10-60 Castrol Edge full synthetic, oil filter
  • 01/03/2006    64,518 miles. Rear shock absorber, rear spring, rear top arms
  • 01/07/2006    65,000 miles. Fitted UK Brake Callipers, UK Discs, UK Pads
  • 01/01/2007    66,181 miles. 10-60 Castrol Edge full synthetic, oil filter
  • 01/08/2007    Floor mats
  • 01/01/2008    68,400 miles. 10-60 Castrol Edge full synthetic, oil filter
  • 01/05/2008    Fit dash rings
  • 01/07/2008    68,620 miles. Front link arms, clear front repeater indicator lights fitted, remove/repaint front bumper, fit with new clips. Fit engine under tray.
  • 01/09/2008    Fit new aerial
  • 01/10/2008    69,800 miles. Fit new radiator, new Toyota coolant, new Greddy top hose, new bottom hose
  • 01/01/2009    70,210 miles. 10-60 Castrol Edge full synthetic, oil filter, boot rubber kit
  • 01/08/2009    Fit new valve stem seals, hoses, new plastic plugs
  • 01/11/2009    Lumber sensors
  • 01/10/2010    73,920 miles. 10-60 Castrol Edge full synthetic, oil filter
  • 01/03/2011    74,005 miles. New interior, gearbox oil, bonnet scoop
  • 01/07/2011    GS-300 wheels & tyres, new front lights
  • 01/10/2011    74,283 miles. 10-60 Castrol Edge full synthetic, oil filter, air filter, fuel filter, rear brake pads, new battery
  • 01/03/2012    Strip front callipers, stainless steel pistons, front brake pads, new Goodridge hoses, new seal kits (Chris Wilson)
  • 05/08/2012    76,484 miles. 5-40 Fuchs Silkolene / Titan Pro S oil change, Lexus oil filter
  • 18/08/2012    Refurbished front & rear wiper arms, fitted Greddy radiator cap
  • 20/11/2012    (Chris Wilson) Upgraded to BPU - Walbro fuel pump, 3" Whifbitz S/S decats, 3" Whifbitz S/S single box exhaust, Whifbitz restrictor ring, NGK cold spark plugs, RL Traction Control New Coil Pack Clips Fitted
  • 01/03/2013    New Toyota Fan/Aux Belt Fitted, Refurbished Battery Tie & Radiator Bottle Holder
  • 22/06/2013    New IACV VSV Fitted & 2 x Vacuum Hoses
  • 01/07/2013    New ABS Wheel Sensor Fitted - Chris Wilson
  • 30/10/2013    Multiple Hoses Replaced
  • 01/02/2014    New Toyota UK Spec Battery and new Battery Terminals Fitted
  • 08/02/2014    UK Spec Toyota Battery Clamp, Rod, Nut, Bolt Fitted
  • 09/03/2014    Fitted New Bosch Aero Wiper Blades (Front & Rear)
  • 22/03/2014    79,050 miles 5-40 Fuchs Silkolene / Titan Pro S Oil Change, Lexus Oil Filter, Drain Plug Washer
  • 22/03/2014    New Copper Contacts & Plunger replaced in the Starter Motor
  • 25/04/2015    Toyota - 80,846 miles 5-40 Fuchs Titan Pro S Oil Change, Lexus Oil Filter, Drain Plug Washer
  • 09/05/2015    Auto Gearbox Pan Oil Change, Strainer/Filter Change, Drain Plug Washer Change Using Toyota T-IV Auto Gearbox Oil
  • 10/10/2015    P/S Reservoir cleaned out, both top and bottom P/S reservoir hoses replaced, hose clips replaced, reservoir holding bolts replaced, lower hose to P/S Pump O Ring replaced, refilled with Dextron 3 ATF
  • 07/11/2015    New genuine Toyota Crank Shaft pulley fitted
  • 05/12/2015    Pem Tyres - Wheel Balance / Seal Bead
  • 20/03/2016    82,823 miles 5-40 Fuchs Titan Pro S Oil Change, Lexus Oil Filter, Drain Plug Washer
  • 20/03/2016    Toyota Coolant Top Up
  • 10/11/2016    New Front Tyres Fitted - Avon ZZ5 - 85,810 miles
  • 14/11/2016    New Rear Tyres Fitted - Conti Sport Contact 3
  • 22/02/2017    New Genuine Toyota Cambelt, Tensioner & Tensioner Pulley, Gates Fan/AUX Belt, New Toyota Radiator (Chris Wilson) & New Coolant
  • 25/03/2017    Fitted OEM Facelift Analog Dash Clock, previous one stopped working
  • 02/11/2020    Chris Wilson - Replaced drivers side worm gears in the seat mechanism
  • 24/01/2021    86,879 miles 5-40 Fuchs Titan Pro S Oil Change, Lexus Oil Filter, Drain Plug Washer
Main Modifications:
  • Upgraded to BPU - Walbro fuel pump, 3" Whifbitz S/S decats, 3" Whifbitz S/S single box exhaust, Whifbitz restrictor ring, NGK cold spark plugs
  • RaceLogic Traction Control
  • Supra front & rear floor mats
  • Leather front & rear interior & door cards
  • Side Skirts
  • Rear Spats
  • Rear Parking Sensors
  • Greddy top radiator pipe
  • GS-300 Alloys (including 1 spare Alloy & Tyre)
  • UK Spec larger Supra Calipers & Discs fitted
  • Included in the sales is a colour matching leather steering wheel & centre console lid (same as seats)
  • I will also include the standard exhaust and both CATS, spare engine and gear box oil etc.
Good bits:
  • No dents, rot or rusty arches
  • The undercarrage is in amazing condition (the words of the Toyota Engineer when it went in for an MOT).  Any under vehicle inspection is welcome.
  • Engine runs perfectly with zero issues or smoke
  • Auto Gear Box opperates like new, with no noises or issues
  • The car has been well maintained by perfectionists
  • The bodywork, interior, engine bay, engine are in very good condition, it really is a fantastic example
  • I was a regular at the North West meets.
  • In my possession the car has never been to a car wash, its been done by me using a 2 bucket wash method, including a foam cannon pre-wash to. (I know how particular the previous owner was aswell so I am pretty sure it was treated the same when he owned it.
  • Previous owner was also a member of the Supra Owners Club
  • BPU and various other work carried out by Chris Wilson (which the majority on here rate as one of the best Supra experts in the UK)
Bad bits: (I am being overly picky with these and really struggling to think of anything else)
  • A single vertical 5cm scratch on the rear bumper, it is on the part that curves under the car so can't be seen.
  • 3-4 stone chips that have been touched up over the years, few chips that could do with touching up
  • A few fine light scratches to the roof, only noticeable in certain lights and at certain angles.
  • A hair line crack (few inches long) in the paint at the bottom of the drivers side skirt (been like this for several years never caused a problem or flaked but was on my list to do)
  • A slight flake of paint on the front bumper, where it rolls in to the arch. (looks like a pressure washer got too close), needs touching up.
I’ve had the car since July 2012 and the people that know me, know how much of a perfectionist I am.  The previous owner from 2005 to 2012 was exactly the same as me.  Money has been no object with this car, if something was needed the best original OEM parts sourced and fitted.  The original headlights went slightly yellow so OEM replacements were purchased from Toyota, I noticed one of the VSV Controllers had a repair on the nipple where the vacuum hose connects, although it operated fine it was replaced with a new one from Toyota, I noticed a couple of the vacuum hoses were not original Toyota ones so these were replaced with original Toyota items.   Receipts can be shown.
As some of you know I have been thinking of selling for 4 years but never wanted to let her go. I am in no rush to sell, but I am serious about selling if the price is met.
Serious enquiries are welcome, I am in West Manchester, 10-15 mins from the Trafford Centre.  No tire kickers, test pilots or dreamers.
Please PM me for a further discussion.
Cheers,
Rick
Edited by r2ck_p (see edit history)
  • Like 3
On 6/1/2021 at 10:09 PM, Annabella said:
Lovely, should sell fine. If it doesn't swap you for an NA and packet of crisps? 😉
Surely the key question is what flavour crisps? Lol.
On a serious note, great advert, great car and hope if it does sell the new owner will cherish it as much as you and the previous owner(s) clearly have.
Best of luck (not that you need it as car is a great example for a good price).
Cheers,
Pete 🙂
Edited by Peter P (see edit history)
This is a cracking car. And one of the best in the country, as we all know as members of the northwest. But me more than most. It’s a few years since I sold my second supra to Biff another northwester and I’m glad I did when I did. I would have bought this car myself If I wasn’t our oldest northwest member and now couldn’t get in or out of a supra because of a knackered hip. New one in a week. Good luck with the sale Rick. Well worth the money but it would have had to be cheese and onion crisps with the deal Annabella.
Edited by Radio (see edit history)
  • Like 2
On 6/5/2021 at 10:47 PM, r2ck_p said:
Thanks for the positive comments. Deposit taken yesterday guys, 3 days from posting the advert.. Should it not get collected next week I will let you know.
It would be great if you could share what it sold for if you'd be happy doing so? Will help those looking at agreed values and those potentially selling 👍
  • Like 1
  • SPG locked this topic
This topic is now closed to further replies.
