scottyt Posted November 5, 2022 Author Share Posted November 5, 2022 On 11/5/2022 at 4:54 PM, rider said: Those rear bars get as bad on the inside as the outside. You might want to consider doing a Dinitrol wax spray inside that will stabilise corrosion and dries leaving a protective wax coat. It comes with a really long diffused spray pattern straw so you can get spraying in far away very inaccessible places. Seeing all those nuts and bolts made me feel queasy. You'll probably find all the bolts come out easy without any need to WD40. The only ones I ever found issues with was where the head of the bolts had corroded badly. Then I had to resort to welding on globs of metal or in the very worst cases a left hand carbide drill. I expect you'll be surprised how easily things come apart though. At least your tank breather pipe is intact, they can sit in fine damp soil to the left of the rubber and rust away. Yours does look a little pitted. These are discontinued so a self build replacement would be needed if it had snapped. I'd recommend sanding it down and clear coating it while you have the tank off to keep the original vent tube going for a good while longer. Expand Yeah will be wax spraying the inside of the bay before it goes back on, I sprayed the inside (through the holes ) with the rust converter and a tube spray I had also. the breather tank pipe is abit to crusty for my liking so my mates making me one as that’s his job he makes pipes/hoses so just taking him the original and he will copy it. I expect he will be doing a few for me as I strip down further 1 Link to comment Share on other sites More sharing options...
scottyt Posted December 28, 2022 Author Share Posted December 28, 2022 Almost finished stripping the rear subframe I’m going to get it blasted then zinc coated but don’t know if I should go powder coating or painted due to chipping. What’s everyone’s thoughts. 1 Link to comment Share on other sites More sharing options...
Peter P Posted December 28, 2022 Share Posted December 28, 2022 On 12/28/2022 at 1:56 PM, scottyt said: Almost finished stripping the rear subframe I’m going to get it blasted then zinc coated but don’t know if I should go powder coating or painted due to chipping. What’s everyone’s thoughts. Expand I’d say powder coated personally, but no doubt others may go painting. I’ve always heard powder coating on all the restoration shows I watch. 1 Link to comment Share on other sites More sharing options...
scottyt Posted January 19, 2023 Author Share Posted January 19, 2023 Rear subframe and a few parts back from blasting 2 Link to comment Share on other sites More sharing options...
zen Posted January 20, 2023 Share Posted January 20, 2023 On 1/28/2022 at 7:08 PM, scottyt said: Working on the interior over the winter, giving her a tidy up in a few places to make her perfect. filled in old holes in dash and new paint, took some time to get it right but I’m really happy with it came out looks like new Expand This is some very nice work. Which product(s) did you use to fill the holes? I need to do this with my dash as well, and I'm struggling to find a decent product that will work. How is the paint holding up? No clear coat? 1 Link to comment Share on other sites More sharing options...
scottyt Posted January 20, 2023 Author Share Posted January 20, 2023 It’s holding up fine the same as the original part , no clear coat just a few coats of the paint and to fill the hold I bonded some plastic to the back just to hold the filler. It was 2 part plastic filler image attached. 1 Link to comment Share on other sites More sharing options...
scottyt Posted January 25, 2023 Author Share Posted January 25, 2023 First of the new parts arriving 2 Link to comment Share on other sites More sharing options...
scottyt Posted February 13, 2023 Author Share Posted February 13, 2023 Handbrake/abs cable clips before and after the clean up. 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 5, 2023 Share Posted March 5, 2023 You're doing an awesome job and doing it right! Love the car, you're making good progress 1 Link to comment Share on other sites More sharing options...
Hammer Posted March 11, 2023 Share Posted March 11, 2023 Just looked through this, great work. Supra looks great in white. Keep up the good work. 1 Link to comment Share on other sites More sharing options...
scottyt Posted March 17, 2023 Author Share Posted March 17, 2023 (edited) Refurbished parts are back . Hubs rebuilt and arms with new ball joints . New abs sensors also Edited March 17, 2023 by scottyt Used wrong picture (see edit history) 2 Link to comment Share on other sites More sharing options...
scottyt Posted March 17, 2023 Author Share Posted March 17, 2023 They arrived today and pick this up tomorrow it like Christmas 2 Link to comment Share on other sites More sharing options...
scottyt Posted June 7, 2023 Author Share Posted June 7, 2023 Underside been stripped back to metal rust converter painted on and then zinc painted next job is Epoxy-Mastic under seal will then be starting to put everything back on the car 2 Link to comment Share on other sites More sharing options...
scottyt Posted June 7, 2023 Author Share Posted June 7, 2023 Also new coilovers on the way and U.K. spec brakes 2 Link to comment Share on other sites More sharing options...
scottyt Posted July 31, 2023 Author Share Posted July 31, 2023 All epoxy coated and parts starting to go back on 1 Link to comment Share on other sites More sharing options...
scottyt Posted August 1, 2023 Author Share Posted August 1, 2023 Suspension on 1 Link to comment Share on other sites More sharing options...
scottyt Posted August 5, 2023 Author Share Posted August 5, 2023 First of the new brake lines copied from the old ready to go 2 Link to comment Share on other sites More sharing options...
scottyt Posted August 13, 2023 Author Share Posted August 13, 2023 Underside getting there . Braided lines to clip up next . But rear bumper is back on so starting to look like a car again IMG_0599.MOV 2 Link to comment Share on other sites More sharing options...
scottyt Posted August 24, 2023 Author Share Posted August 24, 2023 Rear axles sorted and U.K. rears are on 2 Link to comment Share on other sites More sharing options...
mwilkinson Posted August 24, 2023 Share Posted August 24, 2023 How are you enjoying the GR Supra? I didn't know you could spec tan interiors? Is that only for the manual? I've had my GR Supra for just over 18 months now and love it. I've just done over 20k miles too. 1 Link to comment Share on other sites More sharing options...
scottyt Posted August 24, 2023 Author Share Posted August 24, 2023 On 8/24/2023 at 8:32 PM, mwilkinson said: How are you enjoying the GR Supra? I didn't know you could spec tan interiors? Is that only for the manual? I've had my GR Supra for just over 18 months now and love it. I've just done over 20k miles too. Expand It’s the special edition manual tan interior with Matt paint . yeah love it not that I’ve done many miles in it I’ve just passed the 350 mile mark spend most of my time in the van Link to comment Share on other sites More sharing options...
mwilkinson Posted August 24, 2023 Share Posted August 24, 2023 Wow that much! You've got a fair few miles left of the engine run in period to go. Mine is my daily driver, so a round trip to the office is just over 150 miles a day. If I could offer any advice it would be to get the car PPF'd, especially if you plan on keeping it for some time. They are absolute stone magnets! 1 Link to comment Share on other sites More sharing options...
TuneR Posted August 25, 2023 Share Posted August 25, 2023 On 3/17/2023 at 12:22 PM, scottyt said: Refurbished parts are back . Hubs rebuilt and arms with new ball joints . New abs sensors also Expand Good job mate (although i'd have stuck with grey but im biased), who did the ball joints for you? Also i thought i read on here that the ABS sensors were discontinued, are they generic ones? 1 Link to comment Share on other sites More sharing options...
scottyt Posted August 25, 2023 Author Share Posted August 25, 2023 On 8/24/2023 at 9:08 PM, mwilkinson said: Wow that much! You've got a fair few miles left of the engine run in period to go. Mine is my daily driver, so a round trip to the office is just over 150 miles a day. If I could offer any advice it would be to get the car PPF'd, especially if you plan on keeping it for some time. They are absolute stone magnets! Expand I am looking at ppf but not sure how it would look with the Matt finish and if I could deal with seeing the edges of the film . But yeah plan on keeping the car forever really Link to comment Share on other sites More sharing options...
scottyt Posted August 25, 2023 Author Share Posted August 25, 2023 On 8/25/2023 at 8:55 AM, TuneR said: Good job mate (although i'd have stuck with grey but im biased), who did the ball joints for you? Also i thought i read on here that the ABS sensors were discontinued, are they generic ones? Expand Andy Ventress did them all for me I’m not sure if he’s on here but he’s on Facebook unrivalled supras . He sells the front and rear sensors for good price as well , I’m not sure what they are off but fit perfectly 1 Link to comment Share on other sites More sharing options...
