Stalling
evinX
It is likely to be a vac leak, in addition to checking all the hoses its worth checking the really old by now brake booster check valve. They can cause air leaks into the manifold that'll lead to idle problems. Things like that you may as well just change if its the original anyway.
Edited by rider (see edit history)
To echo what the other two are saying, I reckon it's also vacuum related. The wiring/connection to my vacuum sensor is a bit iffy at times, when i'd accidentally knocked it before it did have similar symptoms, i.e. it was hunting on idle, very low idle, and it died once (but I just tightened the connection before I drove off, so idk if it'd stall out at a junction etc.), so you might just want to check that's connected properly.
Checked all the vac lines and they looked fine, no splits. Did swap out the ICV for a spare and it didnt cut out or try to, will give itna few days and see what happens. But the ICV i removed looked better than the spare i had.
Pretty sure its not the ECU causing it as the autobox runs fine, no erratic dash/needles. My mind keeps questioning the fuel relay if its fuel related
Cheers for the replys chaps
