Seat base swap. How to?
The Raven
Off memory unzip the back and there’s 2 bolts at each side then slide it upwards so pretty easy. To remove the base remove the large side panel (removing the buttons first) then there’s a bolt at roughly each corner simply remove those and switch them across to the other mechanism👍
  • Like 1
