herbiemercman Posted March 31, 2021 Share Posted March 31, 2021 Hi Guys, Had brake failure two weeks back, a pipe had corroded inside the black plastic protection cover. I am about to replace all the piping with copper, but i would like to know if the Supras have a dual braking system, because if they do, then my system must be faulty as i had no brakes at all. This kind of problem happened a few years ago on my old Merc, a rear brake pipe corroded and i was still left with just the front brakes working, i feel sure the Supras must have this in their design? Any info on this subject will be appreciated. Link to comment Share on other sites More sharing options...
Burna Posted March 31, 2021 Share Posted March 31, 2021 No they don't, hence why you had no brakes. The facelift brake pipework is also different to the pre-facelift pipework. Link to comment Share on other sites More sharing options...
evinX Posted March 31, 2021 Share Posted March 31, 2021 I see alot of people use copper pipe and i wouldnt on a supra. People should be using stainless steel and steel nuts as the cylinder is steel and the flexi pipe fittings are steel to. Zinc coated steel would be fine. Steel touching copper causes corrosion. Electrosys (typo?) Link to comment Share on other sites More sharing options...
Burna Posted April 1, 2021 Share Posted April 1, 2021 11 hours ago, evinX said: I see alot of people use copper pipe and i wouldnt on a supra. People should be using stainless steel and steel nuts as the cylinder is steel and the flexi pipe fittings are steel to. Zinc coated steel would be fine. Steel touching copper causes corrosion. Electrosys (typo?) I don't understand why anyone wouldn't just fit OEM lines, they are still available from Toyota, that's what I did when I replaced all 5 lines. Link to comment Share on other sites More sharing options...
herbiemercman Posted April 1, 2021 Author Share Posted April 1, 2021 Thanks for the info guys. Quite shocked that there is no dual brake system. Link to comment Share on other sites More sharing options...
evinX Posted April 1, 2021 Share Posted April 1, 2021 1 hour ago, Burna said: I don't understand why anyone wouldn't just fit OEM lines, they are still available from Toyota, that's what I did when I replaced all 5 lines. Easily made up for a fraction of the price. Toyota are steel coated in plastic. Stainless steel would be much better imo Link to comment Share on other sites More sharing options...
Burna Posted April 1, 2021 Share Posted April 1, 2021 1 minute ago, evinX said: Easily made up for a fraction of the price. Toyota are steel coated in plastic. Stainless steel would be much better imo To me it's not worth the time, hassle and labour. It's not about the cost of the parts, it's the easiest and quickest solution to the problem. Link to comment Share on other sites More sharing options...
evinX Posted April 1, 2021 Share Posted April 1, 2021 4 minutes ago, Burna said: To me it's not worth the time, hassle and labour. It's not about the cost of the parts, it's the easiest and quickest solution to the problem. I agree but for me i cant rely on Toyota as parts are being discontinued constantly now. Im sure some of the lines for the NA are discontinued to Link to comment Share on other sites More sharing options...
jim_supra Posted April 1, 2021 Share Posted April 1, 2021 12 hours ago, evinX said: I see alot of people use copper pipe and i wouldnt on a supra. People should be using stainless steel and steel nuts as the cylinder is steel and the flexi pipe fittings are steel to. Zinc coated steel would be fine. Steel touching copper causes corrosion. Electrosys (typo?) The same galvanic corrosion process occurs when stainless steel touches plated steel (with Zinc content) the reaction will likely be to a lesser extent than copper with plated steel, but will still happen. 1 Link to comment Share on other sites More sharing options...
