steve spedd Posted March 26, 2021 Share Posted March 26, 2021 (edited) BACK AVAILABLE... £2,950.00 R154 Full conversion kit – Mkiv Supra 2JZ JZA80 Due to personal circumstances this lot is up for sale (going auto): · Mkiii Supra R154 box (good condition with no issues) · 1JZ/2JZ Genuine Bellhousing (RRP: $399 https://www.driftmotion.com/1JZ-2JZ-R154-Bell-Housing-p/dm3.htm) · 2No. cover plated for Bellhousing · Mkiv supra rear gearbox mount · New (never fitted) Mkiv Driftmotion R154/Mkiv rear gearbox mount (New RRP: $129.99: https://www.driftmotion.com/R154-Swap-Mount-Kit-MK4-SC-GS-p/dm2643.htm) · 1JZ Flywheel (suggest this is skimmed prior to use) · ARP Flywheel bolts · Shifter extended to suit MKiv transmission tunnel · Cube short shifter to suit the above · R154 Clutch fork and new pin (pin not shown in the photos) · Used Clutch slave cylinder · Propshaft (mates from R154 to Mkiv small diff) · Clutch master cylinder (used) · Clutch pedal and assembly (not shown in the photos) · Spec Clutch (Stage 3+) done about 1500 miles (RRP £735.70: https://www.garagewhifbitz.co.uk/spec-clutch-1590.html) · Xtreme Clutch (Stage 2) done about 20 miles (RRP: £538.80: https://www.driftworks.com/xtreme-clutch-for-toyota-supra.html) Other than the pipe from the clutch master cylinder to the clutch slave cylinder and a few bolts this is everything you will need to put the R154 into a Mkiv Supra… I’m after £3,250.00 £2,950.00 Collected from Chesterfield. Please take a good look at the photos and message me if you have any questions. I have this for sale else where so if it sell's then i'll remove this... Thanks, Steve Edited April 22, 2021 by steve spedd Back Available (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted March 26, 2021 Share Posted March 26, 2021 Decent price. GLWS Link to comment Share on other sites More sharing options...
mc92 Posted March 27, 2021 Share Posted March 27, 2021 Let me know if you consider selling parts individually. Hopefully someone else buys the lot before that Link to comment Share on other sites More sharing options...
Sanya.kiss83 Posted March 27, 2021 Share Posted March 27, 2021 Hi, would you sell the spec stg3+ clutch kit separately? Link to comment Share on other sites More sharing options...
steve spedd Posted April 22, 2021 Author Share Posted April 22, 2021 For Sale again, revised price... Link to comment Share on other sites More sharing options...
