Tyre advice - novice
Jaycm
Hey all,
I’ve searched many threads but would like your advice if possible.
My BPU Supra has  te37 alloys on in the below fitment -
Rear - 18” x 9.5J pcd 114.3 of+40
Front - 18” x 8.5J pcd 114.3 of+40
With Front - 225x45 r18 Rear - 255x45 r18 tyres, but I feel like they not only look like tractor tyres but feel nothing 😂
can anyone recommend me some sizes to look at ordering tyres wise, the car is a summer time car only and doesn’t see track. After speaking to a few friends I’m probably looking at ordering some MPS4’s but need a good tyre size setup, not looking at stretched tyres etc just something that not only keeps the car on the road but looks as good also.
any help/guidance is appreciated
45 is indeed a large profile. 40 would be ideal for that width.
Here's a handy chart for tyre width recommendations.
https://www.tyresizecalculator.com/charts/tire-width-for-a-wheel-rim-size-chart
Push the widest tyre you can fit is my advice. 9.5J isn't particularly wide so fact you're running then already is positive and no rub hopefully.
Regarding tyre type. I've not met many people that have tried a huge range. Most seems to try a couple then get their favourites. So best to get the best you can afford. Making sure the compound suits your quantity of miles. Dont want to get soft tyres then wonder why you cant do so many miles.
Lots of good reviews on here from people on experiences. Have a little search mate.
  • Like 1
25 minutes ago, Jaycm said:
Also to add to my query, why when searching do some people fit for example 35 height to the rear and 40 to the fronts? Is this big powered Supra’s only?
The height is a percentage of the width. So 35% of the wider rears would roughly equal 40% of the narrower fronts.
Ok so stock tyres are  235/45/17   and   255/40/17      which are 643mm  and 636mm diameter
Your current tyres are  225/45/18 and 255/45/18  which are 660mm and 687mm diameter, so your car will be a bit 'nose down' and approx 1cm higher ride height at the front and approx 2cm higher at the rear (I mention this as going back to the more correct tyres will mean you'll drop lower).
I'm 99% I have 235/40/18  and 255/35/18  which gives 645mm  and 636mm ie very close to the stock wheel sizes, I'm happy with these tyres widths at bpu, if you want wider then  245/40/18 and 275/35/18   653mm and 650mm are often used.
https://www.willtheyfit.com/index.php?width=245&aspect=40&diameter=18&wheelwidth=9.5&offset=40&width2=275&aspect2=35&wheel_size=18&wheel_width=9-5&offset2=40
  • Like 2
