Bender Posted March 17, 2021 Share Posted March 17, 2021 I try to remove carpet as had a new one so in order to do that i was start removing seats passanger one took me 2 min but driver one stuck (i think i go to far) no it feels like only one rail working as it should one small plastic part comes off (see pic) is there any way how can i remove that seat? Link to comment Share on other sites More sharing options...
Bender Posted March 17, 2021 Author Share Posted March 17, 2021 Been told there is some kind of screw where you can manualy move it... Its true? Link to comment Share on other sites More sharing options...
Konrad Posted March 20, 2021 Share Posted March 20, 2021 both sides can be turned manually from the front of the seat. I think it was hex key, but it was ages ago since i had to do that. Just look under seat from front where rail meets seat. Link to comment Share on other sites More sharing options...
Bender Posted March 21, 2021 Author Share Posted March 21, 2021 5 hours ago, Konrad said: both sides can be turned manually from the front of the seat. I think it was hex key, but it was ages ago since i had to do that. Just look under seat from front where rail meets seat. Thanks Konrad already sorted out 1st part - taking seat from the car now i need to fix that mechanism somehow as the both sides not aligned so seat only move couple of cm Link to comment Share on other sites More sharing options...
Konrad Posted March 22, 2021 Share Posted March 22, 2021 If both sides are moving with same speed, it is just matter of tinkering until you set seat straight. There is also small part there with spiral thread, its plastic and tend to fail. I think ive seen someone selling metal equivalent of this for mk4 supra seat. Link to comment Share on other sites More sharing options...
