Painting the Polyeurathane lips
tayr
Hi all
Anyone Had any troubles painting the RMM lips?
Quite fancy painting it from The standard black to white but as they flex quite a lot I wondered if they crack. Also does paint actually stick to it?
If anyone knows somewhere I can buy one already painted that would be cool
You need to really clean the plastic first. Then use a proper plastic primer (adhesion promoter) then a 2k high build with about 5% elastic mixed into it and the same for base and clear if you really want it to flex without slitting/ cracking
  • Like 1
