Sound performance torque monster kit turbo kit 4” dp 4” mp
supradanturbo
For sale I have my single turbo kit, just taken off my supra.
The kit is a sound performance torque monster kit.
Minus turbo !!
Sound performance cast manifold. Ported for flow. Wastegate opened out to accept 46mm precision gate. Wastegate flange welded to prevent blowing out gaskets all the time. Holds boost perfectly.
1/8npt egt probe hole.
46mm precision wastegate. 10psi spring is gate. Second spring included.
4” downpipe and mid pipe.
Mid pipe extended to match standard catback location. All Vband clamps.
Downpipe has bosses for stock lambda sensor. And 14mm aftermarket sensors.
Oil feed and drain. Extended oil drain flange.
Block fitting.
Hot side intercooler piping down to. iC inlet.
Both couplers. All jubilee clips.
4” intake pipe with k&n filter
Turbo blanket in useable condition.
This kit made 715bhp on vpower at 1.5 bar
And 821hp on 50% ethanol at 1.6 bar using a precision 6766
£1100
located in Brighton.
Edited by supradanturbo (see edit history)
  • supradanturbo changed the title to Sound performance torque monster kit turbo kit 4” dp 4” mp
