Steering wheel question
JordanC
1 minute ago, m12aak said:
If your car doesn't have an existing airbag, there's no need for a harness, but if it does, you'll need this harness: 09082-00760 for it to work.
It can be fitted w/o the harness but you'll likely have an airbag light on (and it obviously won't work!)
Great thanks, have just ordered one off amayama so should be here in a few weeks.
  • Like 1
8 hours ago, Noz said:
Did you wire up the airbag in the end
yezzir
2 minutes ago, JordanC said:
I read somewhere they were discontinued so I didn't even try Toyota directly, it's worked out to be around £10 through amayama
Ah ok, i bought mine a few months back. You will need to wire in your new horn which is easy enough to do, it just slides into a pin adaptor iirc
  • Like 1
