JordanC Posted February 22, 2021 Share Posted February 22, 2021 So I was hoping to change out my current steering wheel for one of these style wheels: I have a 94 JDM RZ TT, is this going to be a straight swap or do I need anything additional? I read somewhere about needing a harness or can it still be fitted without one? Quote Link to comment Share on other sites More sharing options...
m12aak Posted February 22, 2021 Share Posted February 22, 2021 If your car doesn't have an existing airbag, there's no need for a harness, but if it does, you'll need this harness: 09082-00760 for it to work. It can be fitted w/o the harness but you'll likely have an airbag light on (and it obviously won't work!) Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 22, 2021 Author Share Posted February 22, 2021 1 minute ago, m12aak said: If your car doesn't have an existing airbag, there's no need for a harness, but if it does, you'll need this harness: 09082-00760 for it to work. It can be fitted w/o the harness but you'll likely have an airbag light on (and it obviously won't work!) Great thanks, have just ordered one off amayama so should be here in a few weeks. 1 Quote Link to comment Share on other sites More sharing options...
tayr Posted February 22, 2021 Share Posted February 22, 2021 3 hours ago, JordanC said: Great thanks, have just ordered one off amayama so should be here in a few weeks. I got mine from Toyota about £15 iirc Quote Link to comment Share on other sites More sharing options...
Noz Posted February 23, 2021 Share Posted February 23, 2021 3 hours ago, tayr said: I got mine from Toyota about £15 iirc Did you wire up the airbag in the end Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 23, 2021 Author Share Posted February 23, 2021 11 hours ago, tayr said: I got mine from Toyota about £15 iirc I read somewhere they were discontinued so I didn't even try Toyota directly, it's worked out to be around £10 through amayama Quote Link to comment Share on other sites More sharing options...
tayr Posted February 23, 2021 Share Posted February 23, 2021 8 hours ago, Noz said: Did you wire up the airbag in the end yezzir 2 minutes ago, JordanC said: I read somewhere they were discontinued so I didn't even try Toyota directly, it's worked out to be around £10 through amayama Ah ok, i bought mine a few months back. You will need to wire in your new horn which is easy enough to do, it just slides into a pin adaptor iirc 1 Quote Link to comment Share on other sites More sharing options...
