Running issue linked to check engine light!
Chrisbeast
Hi all.
I have a running issue with my '93 jspec tt 6 which started out end of last year.
I go to start car, turn ignition on and I've noticed the check engine and slip cont lights don't illuminate. If i then crank engine it'll start but just die after a few seconds.
Where as if i just leave the ignition on for about four or five minutes the check engine and slip cont lights will illuminate and the car will then run perfectly.
I'm quite stumped on this one, wondering if its an immobiliser problem? I have a Cobra 7925 control/siren with 1984 immobiliser.
Any help on this would be great, regards Chris.
Hi, sorry I should have mentioned about fuel pump ecu following on from my post last year. I had pump ecu error code come up so in the end replaced pump ecu with brand new.
The new ecu sadly made no difference car will only start & run properly depending on engine check light illumination! The same is the case with the old pump ecu too.
