SuperSupra Posted October 11, 2005 Share Posted October 11, 2005 Coming to work this morning and as I approached a junction - SQUEEEEEEEEEEEEEEK!!! Oh my god how embarrassing! Never had a car with squeeky brakes, is this a common Supra issue and what's the best medicine for them??? Link to comment Share on other sites More sharing options...
Marco Posted October 11, 2005 Share Posted October 11, 2005 Check your brakepads Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted October 11, 2005 Share Posted October 11, 2005 Check your pads as they could be getting to the time to change them, they squeek as a warning. On the other hand, my Brembos squeal like mad, so it could just be that you are unlucky. Link to comment Share on other sites More sharing options...
SuperSupra Posted October 11, 2005 Author Share Posted October 11, 2005 Check your brakepads Just had them replaced a couple of weeks ago on the service. Fronts were replaced, and I think the squeeking is coming from the fronts. It's a bitch! Is there anything you can do to get rid of it? Link to comment Share on other sites More sharing options...
Bobbeh Posted October 11, 2005 Share Posted October 11, 2005 Do you pads have the anti squeal shims with them, or were they thrown away? Link to comment Share on other sites More sharing options...
SuperSupra Posted October 11, 2005 Author Share Posted October 11, 2005 Do you pads have the anti squeal shims with them, or were they thrown away? Good question, haven't got a clue! They were changed by Chris Wilson so I guess only he'll know! Or I can look when I finish work but not sure I'll know what I'm looking for! Link to comment Share on other sites More sharing options...
penguin Posted October 11, 2005 Share Posted October 11, 2005 grease them Link to comment Share on other sites More sharing options...
Bobbeh Posted October 11, 2005 Share Posted October 11, 2005 They're thin metal strips on the side of the pad that sit between the pad and the piston... you may not have had them on before so he may not have had anything to put on... but a lot of people thrown them away anyway. Chris probably thought they add weight to the car Link to comment Share on other sites More sharing options...
SuperSupra Posted October 11, 2005 Author Share Posted October 11, 2005 Hmmm, can I get hold of them, and how would I go about greasing them? Sorry I'm retarded when it comes to brakes!!! Link to comment Share on other sites More sharing options...
Bobbeh Posted October 11, 2005 Share Posted October 11, 2005 Copper grease, any mechanic should have a pot of this..and yeah you can get shim kits from Toyota. Chris even may have spares at his place. Link to comment Share on other sites More sharing options...
supRo Posted October 11, 2005 Share Posted October 11, 2005 If you haven't got em, then yes you can get them from toyota. With the anti-squeel shims on, you don't need to use copper grease. If you haven't got them, I may have some spare (front J spec), PM me and I'll post them out tonight. Ro Link to comment Share on other sites More sharing options...
SuperSupra Posted October 11, 2005 Author Share Posted October 11, 2005 Sweet, cheers for that, hopefully that'll sort it! Link to comment Share on other sites More sharing options...
dangerous brain Posted October 11, 2005 Share Posted October 11, 2005 Check your pads as they could be getting to the time to change them, they squeek as a warning. On the other hand, my Brembos squeal like mad, so it could just be that you are unlucky. Discs you mean of the grooved variety? Mine do as well mucho annoying. Wash the wheels out regularly though and its not as bad. Link to comment Share on other sites More sharing options...
SuperSupra Posted October 11, 2005 Author Share Posted October 11, 2005 Discs you mean of the grooved variety? Mine do as well mucho annoying. Wash the wheels out regularly though and its not as bad. Must admit when i washed my car very thoroughly the other day they didn't make an ounce of a squeek! Might just have to wash a bit more often, my car that is!!!! Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 11, 2005 Share Posted October 11, 2005 They VERY rarely squeal, so I expect they may just be bedding into the discs. If it persists i will post you an anti squeal shim kit FOC, but i have only once had to use them with my fast road pads, and that was with someone using grooved or drilled 9can't recall which) Taiwanese discs. Give them a couple of hundered miles to bed fully, if it persists just ring me and I'll post you some off. Sorry you have this noise. Link to comment Share on other sites More sharing options...
