Single Turbo water and oil feed
Supra-love
Just wondering what size the water feed/return should be from a single turbo?
Im looking to use 5/8” reinforced diameter hose. Just want to make sure this is the best size to use for turbo water feeding/returning.
Water feed will come from the water pump nipple and return to the upper radiator water neck.
The oil feed will be -4 and will have a 1mm restrictor following the turbos recommendation.
oil return will be 10an to sump
