EGCV valve sticking
adi2009
Hi there, I ve been trying to diagnose a sequential turbo issue in my Gen 2 Aristo and after changing most of the vacuum lines and testing the vsv's I've narrowed down the issue to a sticking EGCV valve / Actuator. I tried using compressed air in the actuator and it reluctantly opened but will not close when the pressure is off. I need to change the EGCV valve and actuator, has anyone done this before? If so, do I need to remove the turbos or can it be worked on from the bottom of the car?
PS: I have a supra too and I know the chassis is different.
