edviss Posted January 8, 2021 Share Posted January 8, 2021 Hi All, I did use search button guys, with no luck I am currently running NA-T with stock 330cc high impendence Injectors and GE ECU + Greddy piggyback. I am moving to GTE ECU + Greddy piggyback for smart coil upgrade to delete dizzy, which will involve upgrading injectors as my old ones are currently maxing out. With GTE ECU do I still run High impendence injectors or do I need to move to low independence? As Injectors are driven by ECU thats where I got confused. Thanks, Ed Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 9, 2021 Share Posted January 9, 2021 Jspec GTE ECU will require the use of high impedance injectors. UK spec GTE ecu will use low impedence injectors & a resistor pack.   Quote Link to comment Share on other sites More sharing options...
