RobSheffield Posted October 11, 2005 Share Posted October 11, 2005 my car failed MOT on one bottom ball joint being faulty, the other side was fine would it be sensible to replace just the one to pass MOT, then do the other one over winter? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 11, 2005 Share Posted October 11, 2005 Why are people suddenly having lower front wishbone ball joint issues? I have one regular car on 300,000 pus miles, ball joints perfect, another 250,000 plus miles, same. I suspect BIG wheel / tyre combos are causing this, are you on big rims Rob, if you don't mind me asking? Carlos has had his lower ball joints give wear issues, he's on big rims... Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 11, 2005 Share Posted October 11, 2005 We're both on 19s Chris I don't know about Rob's, but my Wheel Manias weigh a feckin' tonne. Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 11, 2005 Share Posted October 11, 2005 my car failed MOT on one bottom ball joint being faulty, the other side was fine would it be sensible to replace just the one to pass MOT, then do the other one over winter? The only problem I can see is that you are probably going to have to pay ~£120 for a proper wheel-alignment job after making a mess of the camber, so it would be a pain to have to pay that again. If I get any spare cash I'll be doing my other side ASAP so I have a nice posh new front-lower suspension, then get it aligned. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 11, 2005 Author Share Posted October 11, 2005 Why are people suddenly having lower front wishbone ball joint issues? I have one regular car on 300,000 pus miles, ball joints perfect, another 250,000 plus miles, same. I suspect BIG wheel / tyre combos are causing this, are you on big rims Rob, if you don't mind me asking? Carlos has had his lower ball joints give wear issues, he's on big rims... yeah, it was on 18" wheels for a while, now on 19's...sorry Chris! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 11, 2005 Share Posted October 11, 2005 Don't apologize, but DO consider what extar loads are being fed into the suspension to wear out a large, hefty bottom ball joint in a few thousand miles, whereby the stock set up seems good for 200,000 miles plus.... It makes me wonder if we might even be about to see some catastrophic failures on suspension parts soon? I REALLY hope not, but this trend, if it is caused by the weight and inertia of big heavy wheels and tyres, could be becomimng very worrying. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 11, 2005 Author Share Posted October 11, 2005 i would have to agree Chris the nearside wheel bearing was shot, and so is the offside bottom ball joint and track rod ends.... however my car came with a full cage, Hipermax Pro Performer super stiff suspension, an HKS Fcon V and 30,000 miles i would would be tempted to say it had spent a small portion of its life on a track! Quote Link to comment Share on other sites More sharing options...
Alex Posted October 11, 2005 Share Posted October 11, 2005 How do we tell if it's buggered? It just looks wrong or will it knock or something? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 11, 2005 Author Share Posted October 11, 2005 didnt really notice a knock, but it had super stiff suspension on MOT man noticed the MASSIVE play though! Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 11, 2005 Share Posted October 11, 2005 How do we tell if it's buggered? It just looks wrong or will it knock or something? The chap at the garage I use raised the car off it's wheels and used a crowbar as a lever underneath the wheel. The wheel went up and down nearly 2cm on the balljoint. Quote Link to comment Share on other sites More sharing options...
