JamieP Posted July 12, 2021 Author Share Posted July 12, 2021 Ashley prepping the engine bay for paint, getting ready for the engine install. 6 Link to comment Share on other sites More sharing options...
Graham1984 Posted July 12, 2021 Share Posted July 12, 2021 Saw your videos on this pop up on Youtube the other day. Was good to finally read the thread about it, garage also looks great btw. 1 Link to comment Share on other sites More sharing options...
welshbuddy Posted July 13, 2021 Share Posted July 13, 2021 Builds coming on Lovely! The full works! 1 Link to comment Share on other sites More sharing options...
JamieP Posted July 14, 2021 Author Share Posted July 14, 2021 Thanks guys, coming on well. 4 Link to comment Share on other sites More sharing options...
bonus_2000 Posted July 14, 2021 Share Posted July 14, 2021 That's looking really good. 1 Link to comment Share on other sites More sharing options...
mharvey Posted July 14, 2021 Share Posted July 14, 2021 Looks great! Very jealous. Can't wait for mine to get in there now and start looking half as good. 1 Link to comment Share on other sites More sharing options...
JamieP Posted July 30, 2021 Author Share Posted July 30, 2021 Coming on well now 8 Link to comment Share on other sites More sharing options...
mwilkinson Posted July 30, 2021 Share Posted July 30, 2021 Looking lovely. Link to comment Share on other sites More sharing options...
Style Posted August 2, 2021 Share Posted August 2, 2021 Very nice! What's running into the intercooler piping on the intake side? Never seen that before Link to comment Share on other sites More sharing options...
JamieP Posted August 2, 2021 Author Share Posted August 2, 2021 6 hours ago, Style said: Very nice! What's running into the intercooler piping on the intake side? Never seen that before It’s to do with the idle control valve. 1 Link to comment Share on other sites More sharing options...
Dave Posted August 2, 2021 Share Posted August 2, 2021 Wow what a transformation nice work Link to comment Share on other sites More sharing options...
Swampy442 Posted August 2, 2021 Share Posted August 2, 2021 11 hours ago, Style said: Very nice! What's running into the intercooler piping on the intake side? Never seen that before Its pretty common sense on a single turbo car Link to comment Share on other sites More sharing options...
Style Posted August 3, 2021 Share Posted August 3, 2021 12 hours ago, Swampy442 said: Its pretty common sense on a single turbo car Check Billy big bollocks over here I'll be sure to tell everyone I see from now on to whip the little filters off the end of theirs and run it the common sense way instead. Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 3, 2021 Share Posted August 3, 2021 6 minutes ago, Style said: Check Billy big bollocks over here I'll be sure to tell everyone I see from now on to whip the little filters off the end of theirs and run it the common sense way instead. 9/10 times running the filter off the IACV is more than adequate on a GTE setup. Difference is on jamies the inlet manifold is designed for use for NA head. Because of this the idle air control flange they provide on the plenum is for a NA IACV, which does not use the boost check valve like on a GTE, and you cannot use the boost check valve easily as the mounting flange for NA IACV is completely different. So this NA IACV has to be routed back into intercooler system pre TB in order for there not to be a massive boost leak whilst boosting, whilst also allowing the IACV to bypass air around the TB whilst in idle state. 3 Link to comment Share on other sites More sharing options...
Noz Posted August 3, 2021 Share Posted August 3, 2021 24 minutes ago, Mike2JZ said: 9/10 times running the filter off the IACV is more than adequate on a GTE setup. Difference is on jamies the inlet manifold is designed for use for NA head. Because of this the idle air control flange they provide on the plenum is for a NA IACV, which does not use the boost check valve like on a GTE, and you cannot use the boost check valve easily as the mounting flange for NA IACV is completely different. So this NA IACV has to be routed back into intercooler system pre TB in order for there not to be a massive boost leak whilst boosting, whilst also allowing the IACV to bypass air around the TB whilst in idle state. I had my IACV removed, as I had a mk3 IACV and it was turd. Now using a DBW throttle body, was advised I didn't need it. Do have issues on start up though, car will just die. Do you think it could be connected? Link to comment Share on other sites More sharing options...
Style Posted August 3, 2021 Share Posted August 3, 2021 (edited) 26 minutes ago, Mike2JZ said: 9/10 times running the filter off the IACV is more than adequate on a GTE setup. Difference is on jamies the inlet manifold is designed for use for NA head. Because of this the idle air control flange they provide on the plenum is for a NA IACV, which does not use the boost check valve like on a GTE, and you cannot use the boost check valve easily as the mounting flange for NA IACV is completely different. So this NA IACV has to be routed back into intercooler system pre TB in order for there not to be a massive boost leak whilst boosting, whilst also allowing the IACV to bypass air around the TB whilst in idle state. So far from common sense then Thanks Mike, I managed to go DBW at the same time as switching intakes which explains why it's a new concept to me 1 minute ago, Noz said: I had my IACV removed, as I had a mk3 IACV and it was turd. Now using a DBW throttle body, was advised I didn't need it. Do have issues on start up though, car will just die. Do you think it could be connected? I'm DBW and no issues at all, maybe just needs the cold start looked at? Can be hard to get right first time as the cars warm and ideally needs to cool down fully to be properly setup Edited August 3, 2021 by Style (see edit history) Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 3, 2021 Share Posted August 3, 2021 1 minute ago, Noz said: I had my IACV removed, as I had a mk3 IACV and it was turd. Now using a DBW throttle body, was advised I didn't need it. Do have issues on start up though, car will just die. Do you think it could be connected? You won’t need an Iacv if you a drive by wire throttle. If car is cutting out after starting then either it needs more fuel or more air to maintain idle. So probably just needs tune looking at 1 Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2021 Author Share Posted August 3, 2021 (edited) Most the fabrication work done now, fuel system all done, boys also made a custom new engine loom to plug into the S7+, just a few bits like battery relocation to do now. They planning to do first start Thursday I think. Also picked up some recaro seats from an evo 10. Edited August 3, 2021 by JamieP (see edit history) 4 Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2021 Author Share Posted August 3, 2021 Strut brace finishes it off nicely 5 Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2021 Author Share Posted August 3, 2021 IMG_0882.MP4 2 Link to comment Share on other sites More sharing options...
Annabella Posted August 3, 2021 Share Posted August 3, 2021 Sounds lovely, nice burble Link to comment Share on other sites More sharing options...
JamieP Posted August 4, 2021 Author Share Posted August 4, 2021 It’s being straight piped yet Link to comment Share on other sites More sharing options...
jim_supra Posted August 4, 2021 Share Posted August 4, 2021 Very nice, can't believe how quick it's progressed, the difference from January to now is unreal! 1 Link to comment Share on other sites More sharing options...
ben_harmer32 Posted August 4, 2021 Share Posted August 4, 2021 Wander if this Supra ever knew when sitting covered in green slime and dirt that one day it would hit the jackpot One hell of a transformation! Looking great and sounding epic! 2 Link to comment Share on other sites More sharing options...
Tyson Posted August 4, 2021 Share Posted August 4, 2021 5 hours ago, ben_harmer32 said: Wander if this Supra ever knew when sitting covered in green slime and dirt that one day it would hit the jackpot One hell of a transformation! Looking great and sounding epic! Fantastic transformation! Hit the jackpot now until it hits the street and Jamie makes it squeal 1 Link to comment Share on other sites More sharing options...
