AC93 Posted December 31, 2020 Share Posted December 31, 2020 (edited) Hi all, So now my Supra is running and these bits are surplus Plenty plenty more will be for sale including GE non VVTi engine and W58 gearbox kit, plus all ancillaries from GE VVTi engine - just need to sort it through and get pics but for now: Brand new - TPS, Bosch knock sensors and Bosch MAP sensor, AN10 drain pipe and fitting were fitted but never used Diff - A01A - £150 MAP sensor - £25 Fuel pump ECU - £50 AN10 Extended drain fitting and drain line (straight on turbo end, 45 degree on sump end) with Aerospace heat sleeve - £30 AN10 standard fitting flange (perfect for na-t sumps) £10, packaging opened but never fitted! Grey cat temp sensor (I think) - £10 Diff shell (200mm) - £50 or £80 with the missing bits (ring/axle joints etc. sold as spares) Coolant res bottle - £15 GE exhaust manifold/downpipe - £50 HKS mushroom filter - £15 GE VVTi inlet manifold - £20 Charcoal canister - £20 OEM Knock sensors - £20 (both) GE igniter - £40 No idea if these prices are ridiculous or reasonable, open to offers Collection from Luton / St. Albans / Milton Keynes Edited April 24, 2021 by AC93 Update (see edit history) Link to comment Share on other sites More sharing options...
Mugello Posted January 2, 2021 Share Posted January 2, 2021 I will take the 'TPS sensor and the Bosch knock sensors' you have a PM Link to comment Share on other sites More sharing options...
evinX Posted January 2, 2021 Share Posted January 2, 2021 A few gs300 parts in there... Link to comment Share on other sites More sharing options...
safcdixon Posted January 2, 2021 Share Posted January 2, 2021 Price on the w58 conversion please Link to comment Share on other sites More sharing options...
AC93 Posted January 3, 2021 Author Share Posted January 3, 2021 7 hours ago, evinX said: A few gs300 parts in there... Yeh some bits are from a GE VVTi block left over from build Link to comment Share on other sites More sharing options...
AC93 Posted January 3, 2021 Author Share Posted January 3, 2021 7 hours ago, safcdixon said: Price on the w58 conversion please Be up for sale later this month when I get a few other bits out the way.. Will check what the market rate is and then go from there Link to comment Share on other sites More sharing options...
AC93 Posted January 3, 2021 Author Share Posted January 3, 2021 (edited) Also for sale: Ford 2 Pin Idle Control valve, ideal for saving outputs on your ECU Brand new, never used. 5 year warranty - £40 SOLD ---------------------------- 3" black intercooler pipe kit: Cost me £120, open to offers 2x straights 2x 45 degrees 2 x 180 degree bends, bag of clamps and joiners Edited January 4, 2021 by AC93 ICV sold (see edit history) Link to comment Share on other sites More sharing options...
AC93 Posted January 4, 2021 Author Share Posted January 4, 2021 Sold: TPS Ford ICV Knock sensors D1 Catch can Open to offers on everything! Link to comment Share on other sites More sharing options...
AC93 Posted January 10, 2021 Author Share Posted January 10, 2021 More parts: ECU is Supra GE manual £200 Other ECU is GS300 in engine bay case £35 Cams are GE VVTi £25 Engine harness is GS300 VVTi £30 Alternator £20 Everything else is £10 + postage, some bits are free as untested Link to comment Share on other sites More sharing options...
AC93 Posted January 10, 2021 Author Share Posted January 10, 2021 Oil filter housing and bolt £20 Link to comment Share on other sites More sharing options...
AC93 Posted January 10, 2021 Author Share Posted January 10, 2021 Lower water neck sold Link to comment Share on other sites More sharing options...
AC93 Posted January 14, 2021 Author Share Posted January 14, 2021 Lower GE inlet manifold sold Link to comment Share on other sites More sharing options...
AC93 Posted January 15, 2021 Author Share Posted January 15, 2021 Ring gear sold Link to comment Share on other sites More sharing options...
AC93 Posted January 17, 2021 Author Share Posted January 17, 2021 Tensioner sold VVTi loom sold HKS filter sold GS300 air inlet and maf sold 3x GS300 O2 sensors sold Link to comment Share on other sites More sharing options...
AC93 Posted January 22, 2021 Author Share Posted January 22, 2021 Found this if it's any good to anyone - Vacuum sensor Link to comment Share on other sites More sharing options...
AC93 Posted February 3, 2021 Author Share Posted February 3, 2021 Bump before parts start going in the bin Link to comment Share on other sites More sharing options...
AC93 Posted February 23, 2021 Author Share Posted February 23, 2021 GE engine upper intake sold Link to comment Share on other sites More sharing options...
AC93 Posted February 23, 2021 Author Share Posted February 23, 2021 Alternator sold Link to comment Share on other sites More sharing options...
AC93 Posted March 10, 2021 Author Share Posted March 10, 2021 Oil return pipe sold IAT boss pipe sold Inlet manifold brace sold Link to comment Share on other sites More sharing options...
AC93 Posted March 15, 2021 Author Share Posted March 15, 2021 Vacuum sensor sold Link to comment Share on other sites More sharing options...
AC93 Posted April 19, 2021 Author Share Posted April 19, 2021 Lower runners sold Oil filter housing sold Link to comment Share on other sites More sharing options...
AC93 Posted April 24, 2021 Author Share Posted April 24, 2021 Last bits for they get binned: New Toyota ATF fluid Stainless OEM exhaust centre section Blitz backbox Link to comment Share on other sites More sharing options...
AC93 Posted April 24, 2021 Author Share Posted April 24, 2021 Link to comment Share on other sites More sharing options...
AC93 Posted May 30, 2021 Author Share Posted May 30, 2021 ATF fluid sold Open to offers on remaining bits! Link to comment Share on other sites More sharing options...
