Robbieg1994 Posted December 30, 2020 Share Posted December 30, 2020 Hi everyone, here for sale I have the coil on plug conversion kit that was meant to go on my NA-T Supra. The kit includes a set of used and a set of new GTE coil packs, a mounting bracket to fit on a GE head, all the pigtails and wiring for the coil packs and a GTE igniter with the plug and wiring. This is the perfect setup if you are thinking of doing the TT ECU to go turbo on a budget. A friend of mine uses this same setup on his 1000hp 3.4 stroker so it's perfectly capable of holding more power than the TT ECU can give. I also have a GTE MAP sensor for sale too with the pigtail aswell. I would like GBP 350 for the whole set but I am open to offers. I would prefer to post due to covid but pickup is possible aswell. Cheers! Rob Link to comment Share on other sites More sharing options...
Edvard Posted January 2, 2021 Share Posted January 2, 2021 Hi, You have a PM. Link to comment Share on other sites More sharing options...
Nathanj1142 Posted January 4, 2021 Share Posted January 4, 2021 does this setup clear the stock GE manifold? Link to comment Share on other sites More sharing options...
Robbieg1994 Posted January 4, 2021 Author Share Posted January 4, 2021 1 hour ago, Nathanj1142 said: does this setup clear the stock GE manifold? Hi Nathan, They can be made to fit but you are best off running a front facing intake manifold. I had a TT intake manifold modified to fit on NA runners. Cheers, Rob Link to comment Share on other sites More sharing options...
Nathanj1142 Posted January 4, 2021 Share Posted January 4, 2021 2 hours ago, Robbieg1994 said: Hi Nathan, They can be made to fit but you are best off running a front facing intake manifold. I had a TT intake manifold modified to fit on NA runners. Cheers, Rob Interesting. Did you use an adaptor plate or have it welded? Did it hit the bonnet at all? Link to comment Share on other sites More sharing options...
Robbieg1994 Posted January 4, 2021 Author Share Posted January 4, 2021 22 minutes ago, Nathanj1142 said: Interesting. Did you use an adaptor plate or have it welded? Did it hit the bonnet at all? Mine was modified by adding material and grinding so it was a direct bolt up. It touched the insulation but didnt touch the metal part of the bonnet. I sold it as I am now going DBW and a different standalone. Link to comment Share on other sites More sharing options...
Nathanj1142 Posted January 5, 2021 Share Posted January 5, 2021 currently doing NA-T myself but keeping the stock GE intake as i've got the whifbitz kit so all piping matches up. Might do this next winter! Will probs go aftermarket but I imagine this being a cheaper and better method rather than buying a sh!t plenum Link to comment Share on other sites More sharing options...
Noz Posted January 5, 2021 Share Posted January 5, 2021 2 hours ago, Nathanj1142 said: currently doing NA-T myself but keeping the stock GE intake as i've got the whifbitz kit so all piping matches up. Might do this next winter! Will probs go aftermarket but I imagine this being a cheaper and better method rather than buying a sh!t plenum Whifbitz do a coil kit that fits the GE intake. Sorry hijack thread. Lovely kit for the price. Especially with mounting bracket. Link to comment Share on other sites More sharing options...
Nathanj1142 Posted January 5, 2021 Share Posted January 5, 2021 2 hours ago, Noz said: Whifbitz do a coil kit that fits the GE intake. Sorry hijack thread. Lovely kit for the price. Especially with mounting bracket. This is the plan! Just wondering if anything else worked. Link to comment Share on other sites More sharing options...
edviss Posted January 6, 2021 Share Posted January 6, 2021 Hi mate, pmed Link to comment Share on other sites More sharing options...
Robbieg1994 Posted January 6, 2021 Author Share Posted January 6, 2021 MAP sensor provisionally sold Link to comment Share on other sites More sharing options...
