clear indicators
dpepper
Hi there, does anyone know if you can get clear indicators for the front, but for the pre face lift, ie they are just orange, no side lights?
I assume the ones ive heard of are for the later style, which have the sidelight in??
cheers
Yes the clear ones people usually talk about are the facelift ones with sidelights built in. I believe it was Snowman who asked the same thing as you and is on the lookout for a clear lense cover for the older style ones.
Best way is to remove the indicators and convert your front fogs so they act as the indicators instead (as long as you dont mind losing your front fogs). Its quite simple to do and gives a much cleaner look. If you want more info then e-mail me. Otherwise try the U.S. supraforums as i think you will stand a better chance getting them from there (watch it though as customs will sting you when the bits arrive)
I am currently in the process of finding somewhere to make/modify the old style indicators in to get clear lenses.
If you see Chase's Avatar, that is the look i want to achieve and didn't want the longer face lift indicators to go in place.
Thankyou to Phil the Fixer who had some old spare indicators that I am using to find the clear ones.
