She's Back! My Supra's revival & an agreed value question.
jim_supra
Hi all, long post alert!
After many years of being off the road, the Supra is now back on it! As a bit of background she’d been off the road for nearly decade owing to an overheating issue, which caused head gasket failure (water pump failure was the initial cause it looks like). Personal circumstance at the time and the following years meant I could not afford the repair bills, but I also couldn’t bear to part with her and so she was laid up a good long while (longer than I’d planned obviously). Fast forward to today where I’ve now been able to give her the attention she deserves and she’s now back to where she needs to be.
It's been weird driving her given it's been so many years since I stopped, but it's also a bit like when i first bought her. I've not fully pushed it yet (only been out 7-8 times so far in last few weeks) due to the weather and I also have the (probably irrational) fear of me binning it straight after getting her back on the road!
I’ve already managed to get an agreed value through my insurer of 25k, however I initially pushed for 30k and am thinking I should still push for 30k, my thought being that I would struggle to get myself an Aerotop Supra (either NA-TT or true TT Aero) in a similar condition to what mine is now for any less money. So anyone’s thoughts on my current agreed value being accurate or not would be appreciated.
Spec/ work done to the car is as follows;
Base Car
1993 Storm Blue Aerotop, originally NA but converted to TT approximately 11 years ago
Shell has approximately 110k miles on it, Engine has approx. 80k miles on but recently fully rebuilt using a rebuilt 60k mile cylinder head.
Tein coilovers
Stock 17’’ Alloys/ 18’’ Japan Racing JR10’s
Whifbitz style front lip
Everything else is now stanard.
Engine
Rebuilt engine using low mileage cylinder head. Cylinder head rebuilt and block decked cleaned & honed by a local engine specialist (Crank polished, head shimmed, hardness tested etc). engine reassembled and put in car by myself with lots of new parts (as below)
Low mileage twin turbo’s and VSV’s from an Aristo installed with all new OEM gaskets, bolts & nuts
All aluminium parts including turbo hard pipes, inlet manifold, sump, engine mounts etc. vapour blasted
Engine run in by Whifbitz on their rolling road and then dyno’d by them, with the car making 325bhp.
New engine (& engine bay) parts include - all items are original Toyota parts except where specified as pattern part
Head Gasket Kit
Head Bolts
Core plugs
Side mount intercooler (and nuts/ bolts)
Intercooler top hose (that connects to inlet manifold)
Intercooler ducting (and bolts)
Oil pump
Front and rear Crank seals
Crank position sensor
Water pump
Radiator (pattern part)
Viscous fan coupling
Thermostat
Cambelt Tensioner
Idler pulley (Koyo)
Alternator (pattern part)
Cambelt
Fanbelt
Crank pulley with new bolt
Timing belt cover lower
Timing belt cover upper
Spark plug cover
Fuse box lid
Cam cover breather hoses
Turbo link pipes (accordion style pipes)
Power steering reservoir
Battery Tray
Battery clamp
Radiator clamps
Radiator fan shroud
Radiator cap
Top and bottom radiator hoses
All rubber water bypass hoses around the engine
Heater matrix Hoses
Turbo drain hoses
Replaced all vacuum lines with Gates hose (got a couple from Toyota where the bend radius required does not allow for Gates hose which just kinks)
Cam cover bolts and washers
OEM Bolts, Nuts & Studs for exhaust manifold, inlet manifold, Turbo hard pipes, oil feeds engine mounts & lots more.
Spring clamps for hoses being replaced
Pattern part oil Pressure switch & knock sensors
Replaced coil pack clips, a couple of injector clips, and a VSV clip that was brittle
Injectors cleaned and flow tested. New OEM seals etc.
Body
Full respray including engine bay
New OEM Body/ Chassis parts include:
Facelift headlights
Facelift front Indicators
Facelift rear lights
Facelift bumper grill bar
Bumper radiator grill bottom trim
Front lip retaining brackets
Front bumper crash foam
Bumper side retainers & bolts
Bumper to bonnet seal & bracket
Number plate holder, nuts, bolts etc.
Scuttle panel
Windscreen seal
Rear window seal
Front & Rear Aerotop seals
Boot seal
Front Hockey Sticks
Rear Hockey Sticks
Lower sill/ rocker trims
Fuel tank cover
Upper Arch liners
Lower Arch Liners
Front and Rear Badges
Front to rear brake lines and fuel lines
Goodridge braided lines to replace rubber flexi brake hoses.
Rear diff rubber mounts
Lower rear suspension arms
Lower rear Toe arms
Handbrake cables
New OEM Interior parts;
Handbrake lever and rubber surround
Auto gear lever
Brake and accelerator pedal covers
Speedo ‘’glass’’ & Speedo bulbs
Climate control buttons and knobs
Boot tools – spanners, screwdriver, spark plug tool, pliers & Chock
second hand black facelift carpet fitted, with black plastic seat trims.
There’s still more I plan to do on her such as interior retrim, more cleaning up of the engine bay and work on cleaning up the underside, which is the bit that lets the car down now (as has surface corrosion on subframe/ diff etc.) However Whifbitz dropped the rear subframe while they were doing the fuel and brake lines and they treated the areas around the mounting points etc. so any surface corrosion didn't progress to anything worse while I wait to begin the full underside refurb. There's also some little niggles with the paint that i need to get rectified too.
I’ve put a few pictures on, but haven’t managed to get any while out and about with nice backdrops etc. as the weather’s been poor over the past couple of weeks when I’ve managed to get out for a drive in her! I'll run the 18's that are in the last pics more in summer I think, not fully sure which wheels i prefer more at the moment. Oh and the pic of the engine bay is part way through the suspension swap and before the rad, fan shroud and power steering tank got replaced, I’ve also taken the TRD spoiler off and put a standard one on.
Jim
  • Like 5
What a stunning car! It's so nice to see a Supra lovingly restored to glory, well done. If it helps I have a GZ Aerotop and tried to get an agreed value insurance policy for £25k - given it's condition, the work carried out and the rarity premium I felt this to be reasonable, however the insurer came back to me a few weeks after the policy was taken out and said they would only agree to £20k. Stupidly I just went along with it but I now regret not challenging the decision or going elsewhere (think I was outside the cooling off period by that time). In short, I think £25k for yours is reasonable, but some insurers seem to disagree! Well done again, great job.
Edited by Hamilton
Spelling (see edit history)
  • Like 1
6 hours ago, AC93 said:
Looks great, a lot of work gone in to that!
Just need to upgrade those Jspecs for TT or LS400 brakes 🤓
I am looking to put the larger TT brakes on at some point when funds allow, baby due in the new year so got my Supra spends out the way early!
Thanks, it's by no means perfect and will continue to be a rolling restoration, but it's well on its way now.
I guess it's the luck of the draw with insurers/ underwriters as to what they're happy with, I'll probably keep reviewing it as I do more work to the car.
21 minutes ago, Kev.O said:
That’s stunning, great work. Am I allowed to say that I prefer the stock alloys, they look great, I presume they’ve had a refurb as the barrels look really smart too.
Thank you, and you're allowed to say whatever you like 🙂
I do like the stock alloys a lot, though I do have an issue with the fronts and how they sit in from the arches and not more flush. I might look at spacers for them in the near future.
They have been refurb'd too, got the powder coaters to spray the centers in the same colour as the alloys then I laquered them.
On 12/26/2020 at 11:25 AM, Shane said:
I remember seeing this as a NA many many years ago, about a month after I bought my first Mkiv, looks great Jim!  But burning question, do you still live in a windmill?
Thanks, and I'm afraid not, my Windy Miller days are long gone! 😀
