Krimi's EU Spec VVTi Supra Single Turbo G35-1050 (The Journey, from Twins to Single)
Krimi
6 hours ago, Krimi said:
Car finished, also I dropped the sideskirts lips to do a new version of it more “Krimi” style hahaha
Also the targa season start up!!
Nice one Krimi, car looks great and hopefully lots of open topped miles ahead for you both. 👍
Time to enjoy it my friend. 🙂
  • Like 1
New things ahead!! Promising summer 🙂
  • Like 1
  • 1 month later...
  • 2 weeks later...
  • 3 months later...
Hello!!
Good news! Everything purchased to do the single conversion after MOT in earlier 2023 🙂
Garret G35-1050 A/R 1.01 its the choice 🙂
The mod list is the next:
Engine:
- Stock Shortblock
- Decarbonized
- New Toyota Oil Pump
- New Toyota Water pump
- New Toyota Timing Belt and hardware
- New Toyota V-belt and hardware
- New gasket and seal engine overhaul kit
- Radium press-in fittings for valve covers
- Nuke Performance Catch Can
- NGK BKR8EIX
- Fluidampr Crank Pulley
- PHR Black edition billet pulleys
- 36-2 Crank gear
- New Toyota Aristo Alternator
- VVTi Intake Manifold modified
Head:
- Decarbonized
- New Toyota Headgasket
- ARP headstuds
EGR full block off mod from the rear side of the head
- Brian Crower springs Ti tops
- Brian Crower billet valve locker
- Full head overhaul and measures by our machine shop
- New OEM Valve seals
- Stock EU/US camshafts
Turbocharger/Exhaust Components:
- Garrett G35-1050 A/R 1.01
- Billet 44um Oil feed filter
- TurboSmart GenV ProGate 50mm
- K&N Long Air Filter
- Boost Pressure hardlines
- CBS Racing Exhaust Manifold Black Ceramic coated and heat wrapped
- Custom Titanium 3.5" Downpipe heatwrapped
- Custom Titanium 3.5" Midpipe
- HKS Carbon Ti Cat-back
Electronics:
- Link G4+ Extreme
- Custom Wiring
- GTR R35 Smart Coil packs conversion
- Link Oil temp and pressure sensor
- Link Fuel temp and pressure sensor
- Link 5Bar MAP Sensor
- Bosch Knock Sensors
- MAC Boost Solenoid Sensor
- Drive By Wire conversion Kit
- Bosch Throttle body 3”
Intake/Cooling:
- APR Cooling Plate
- Mishimoto S-Line Black Intercooler
- Custom 3" FMIC pipes
- Quick Release Security Clamps
- New Toyota Fan Clutch
- New Toyota Thermostat
- New Toyota Fan shroud
- Whifbitz Black Aluminium radiator
- Funk Motorsport Turbo Blanket
Fuel system:
- Deatschwerks 1200cc Injectors
- Radium Fuel Rail Top Feed
- Radium Fuel Filter and mount
- Radium Fuel Pulse Damper
- Radium Twin fuel pump hanger
- Radium Fittings and Fuel Lines
- AEM E85 Fuel Pumps x2
- CBS Fuel Lines Holders
Drivetrain:
- GETRAG V160
- PHR 3.5” Driveshaft
- 220mm B03B diff LSD
- RPS Twin Carbon/Carbon clutch
- Braided clutch line
- OEM Toyota trans fluid
- ARP Flywheel bolts
- New Toyota clutch master cylinder
- New Toyota slave cylinder
Chassis/Handling/Brakes:
- KW Variant 3 Coilovers
- HEL Braided brake lines
- AP Racing DOT 5.1 Fluid
- TRD Strut Bar
Interior:
- Recaro SR3 black retrimed seats
- OEM Black carpet
- OEM new door cards
- OEM new Speaker covers
- OEM Dash panels
- OEM Black leather back seats retrimed
- OEM Carbon 98' Steering wheel
- OEM New Floor mats
- JP Ledworks TRD LED Conversion
- JP Ledworks full LED HVAC conversion
- Innovate Boost Pressure and AFR Gauge
Exterior/Body:
- Full body and underside restoration and repaint in OEM 202 Black
- OEM S2 front wings
- Antenna delete
- Rear wiper delete
- Work Wheels Meister S1 3P 18x9,5 ET24 18x11 ET30 Michelin PS4 245/35/18 Front Michelin PS3 285/35/18 Rears
- RMM Front lip
- TwinZ Add on lips sideskirts carbon fibre
- ProSpec Imports Meisters center caps in billet
- OEM JDM bonnet (Optional: Seibon TS Carbon bonnet)
- Whifbitz Shine Auto rear Carbon DIffuser
- Rear fenders rolled
- Front Fenders rolled
- 1998 OEM new Headlights
- 1998 OEM new Front indicators
- 1998 OEM new Rear tail lights
Edited by Krimi (see edit history)
  • Like 1
On 10/31/2022 at 6:12 PM, Peter P said:
Very nice Krimi! I’m also probably going with the same Garrett G35-1050 when I go single, so keen to see how you get on and what power levels you get. Looking forward to the updates my friend. 👍 🙂
Honestly one of the best options out there, Im not into any HP objective honestly, want in this order, durability, good working, non-headache car hahahaha with more than 500hp with 98 Im done. 🙂
  • Like 1
  • Krimi changed the title to Krimi's EU Spec Supra Single Turbo G35-1050 (The Journey, from Twins to Single)
  • 1 month later...
Hola hermano
What an amazing build krimi
Where in the Canary Islands are you
my dad is from Tenerife and we plan to bring our supras over soon as they are finished and would be nice to meet up with some other supra owners and hits some of the amazing roads these islands have to offer
  • 2 weeks later...
On 12/9/2022 at 9:48 PM, Supraleeturbo said:
Hola hermano
Hi Mr!!
Im in Gran Canaria, 1 hour ferry to Tenerife and we solve the problem of the distance hahaha.
Let me know when you come here and we plan something 🙂
  • 1 month later...
