Request: Differential Cooler Tech Manual
redsupra94
Hello gents,
I am looking for any technical documents regarding the OEM differential cooler. I am looking to drop the differential to replace the bushings and just want to make sure I treat the differential cooler correctly. Don't want to break something if I can avoid it.
Thank you!
Joe
  • 3 months later...
On 12/4/2020 at 12:16 AM, redsupra94 said:
Hello gents,
Thank you!
Joe
Hi Joe,
Do you have a UK/euro spec car? As far as I am aware the diff cooler wasn’t on any other models.
  • 5 weeks later...
On 3/29/2021 at 12:41 PM, Tyson said:
Hi Joe,
Tyson,
Yes I do. My Supra is UK spec and has the diff cooler and other euro specific parts like the headlight washer horns. Most of the time it isn't too much of an issue because the parts are the same as US/J spec. But every once in a while I run into a UK spec issue that I have to research. This forum has been really valuable for that type of info.
Joe
  • Like 1
