KingCole Posted November 28, 2020 Share Posted November 28, 2020 Hi there, I am new to the 2jz platform and I have recently purchased a JDM TT Supra 6 speed. I am looking to install a manual boost controller (as seen by pictures) on the stock twin-turbo setup. After doing some research, I am confused as there are a few ways going about this and need to understand the best and easiest way. I am only looking to up the boost to around 15-16 psi. Does anyone have any idea on plumbing to install MBC on the stock twin turbos? Also which of the lines do I need to tap into? I have also attached the style of boost controller I will be using. I would really appreciate it if someone has actual pictures of this installed which also highlights the lines I need to tap. Cheers Cole Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 29, 2020 Share Posted November 29, 2020 Use an EBC, much safer, more reliable. Quote Link to comment Share on other sites More sharing options...
KingCole Posted November 29, 2020 Author Share Posted November 29, 2020 9 hours ago, Swampy442 said: Use an EBC, much safer, more reliable. Hi Swampy, I will get an EBC later down the line but just wanted to use MBC for the time being. Do you have any idea on the plumbing? Cheers Cole Quote Link to comment Share on other sites More sharing options...
