swiftstu Posted November 28, 2020 Share Posted November 28, 2020 Hi all, ive got a mixture of symptoms, so can’t find an answer from previous posts. My steering is a little twitchy at low speeds- it veers to the left slightly, and feels a bit vague and light- it has been aligned and left the garage ok in that respect, so not sure there. at higher speeds it feels the same but seems to need little adjustments to keep the car in a straight line ( only minor adjustments but more than it should) it sort of mixes symptoms from other posts, but my closest idea is bushes. Any thoughts? Quote Link to comment Share on other sites More sharing options...
rider Posted November 28, 2020 Share Posted November 28, 2020 Most cars will veer slightly left on a normal road due to the camber. See if it does the same on a good size car park. If it does then your alignment does need checking again. If you want a heavier feel then you can set the caster higher. I went for 4 degrees when I had my alignment done to give a heavier feel to the steering. You might want to look at a proper alignment place rather than a garage. Chassis tuning is a bit of a black art. I went to Center Gravity. Quote Link to comment Share on other sites More sharing options...
swiftstu Posted November 28, 2020 Author Share Posted November 28, 2020 (edited) 8 minutes ago, rider said: Most cars will veer slightly left on a normal road due to the camber. See if it does the same on a good size car park. If it does then your alignment does need checking again. If you want a heavier feel then you can set the caster higher. I went for 4 degrees when I had my alignment done to give a heavier feel to the steering. You might want to look at a proper alignment place rather than a garage. Chassis tuning is a bit of a black art. I went to Center Gravity. Thanks Rider- I’m happy the response wasn’t - all the bushes definitely need changing right away. although it is also the same in a wide open flat space... Edited November 28, 2020 by swiftstu (see edit history) Quote Link to comment Share on other sites More sharing options...
mc92 Posted November 28, 2020 Share Posted November 28, 2020 You could try unplugging the plug on the power steering rack for the speed adaptive power steering if you don't like the feel of it at lower speeds. I much prefer it to be a bit heavier. Quote Link to comment Share on other sites More sharing options...
swiftstu Posted November 28, 2020 Author Share Posted November 28, 2020 30 minutes ago, mc92 said: You could try unplugging the plug on the power steering rack for the speed adaptive power steering if you don't like the feel of it at lower speeds. I much prefer it to be a bit heavier. Thanks- I wish I understood how to do that. But great suggestion ta. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 2, 2020 Share Posted December 2, 2020 Tracking a mile out, probably toeing out? Wrong offset wheels, silly size wheels and tyres? Could be a problem from the back end, also. Bushes in lower front wishbones could be shot. Should be easy enough to trace. On sensible rims and tyres the car shouldn't do this. Quote Link to comment Share on other sites More sharing options...
swiftstu Posted December 10, 2020 Author Share Posted December 10, 2020 On 12/2/2020 at 1:54 PM, Chris Wilson said: Tracking a mile out, probably toeing out? Wrong offset wheels, silly size wheels and tyres? Could be a problem from the back end, also. Bushes in lower front wishbones could be shot. Should be easy enough to trace. On sensible rims and tyres the car shouldn't do this. Hi Chris, Thanks for the reply, I missed the notification somehow - sorry. Good heads up - I'm sensing bushes, but it is also sitting on large wheels so that may not help. Ta Quote Link to comment Share on other sites More sharing options...
evinX Posted December 15, 2020 Share Posted December 15, 2020 19" in winter? Failing that id steer towards crap tyres. Does it feel like the car slips to one side? Quote Link to comment Share on other sites More sharing options...
swiftstu Posted January 18, 2021 Author Share Posted January 18, 2021 On 12/15/2020 at 12:53 PM, evinX said: 19" in winter? Failing that id steer towards crap tyres. Does it feel like the car slips to one side? Sorry @evinX - I've not been getting notifications on posts in my email, but have over the last few weeks. It does steer to the left a bit, but it's more the micro corrections on the wheel that annoy me. It's like my hands need to constantly move to keep the car straight. It's like the front wheels are wobbling a little. I think I'll have them look at it when I have it serviced next month - and prepare my wallet for the impending doom... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2021 Share Posted January 18, 2021 (edited) borrow a set of wheels and tyres like the car was designed to run on (17 inch with the correct offset, and the correct width and profile tyres). If the issue disappears then whoever flogged you the rims and tyres sold you stuff unsuitable for the correct operation of the car. IMO the cars are horrible on 19 inch rims and tyres, manageable OK on 18 inch, very nice on 17 inch, and in difficult wet or slippery conditions and poor road surfaces, a dream on 16 inch. But appearance usurps practicality in many cases, hence the sweaty palm, whoooah, where's it going now feeling driving poorly modded cars and wallet damage and court time with exotic women, especially if you marry one Edited January 18, 2021 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Tyson Posted January 18, 2021 Share Posted January 18, 2021 6 hours ago, Chris Wilson said: borrow a set of wheels and tyres like the car was designed to run on (17 inch with the correct offset, and the correct width and profile tyres). If the issue disappears then whoever flogged you the rims and tyres sold you stuff unsuitable for the correct operation of the car. IMO the cars are horrible on 19 inch rims and tyres, manageable OK on 18 inch, very nice on 17 inch, and in difficult wet or slippery conditions and poor road surfaces, a dream on 16 inch. But appearance usurps practicality in many cases, hence the sweaty palm, whoooah, where's it going now feeling driving poorly modded cars and wallet damage and court time with exotic women, especially if you marry one And even dreamier in forged magnesium Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 19, 2021 Share Posted January 19, 2021 What brand of tyres? Quote Link to comment Share on other sites More sharing options...
swiftstu Posted January 25, 2021 Author Share Posted January 25, 2021 (edited) On 1/18/2021 at 4:04 PM, Chris Wilson said: borrow a set of wheels and tyres like the car was designed to run on (17 inch with the correct offset, and the correct width and profile tyres). If the issue disappears then whoever flogged you the rims and tyres sold you stuff unsuitable for the correct operation of the car. IMO the cars are horrible on 19 inch rims and tyres, manageable OK on 18 inch, very nice on 17 inch, and in difficult wet or slippery conditions and poor road surfaces, a dream on 16 inch. But appearance usurps practicality in many cases, hence the sweaty palm, whoooah, where's it going now feeling driving poorly modded cars and wallet damage and court time with exotic women, especially if you marry one Thanks Chris. I'll track down some when I can and give that a try. The wheels came with the car, so didn't question it. The issue seems to be worse though Edited January 25, 2021 by swiftstu (see edit history) Quote Link to comment Share on other sites More sharing options...
swiftstu Posted January 25, 2021 Author Share Posted January 25, 2021 On 1/19/2021 at 9:29 PM, Swampy442 said: What brand of tyres? They are Avon ZZ5 tyres - 235/ 40 / 18. Going in for a service Saturday, so getting them to have a look whilst there. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 25, 2021 Share Posted January 25, 2021 They are certainly not an outrageous size to be fair. But I would have concerns as to the make and model , especially in the wet, my experience of these is they are good ditch finders in the damp / wet. 1 Quote Link to comment Share on other sites More sharing options...
