Aftermarket Standalone ECU using Stock Intake and sub throttle valve
Andy Ven
Hi Gents,
 I am currently going through building my wiring loom for my Link Thunder ECU and want to know if anyone with a standalone is still using the stock intake and Sub throttle valve? I plan on keeping it and using it as a traction control system.
If anyone is still using it hit me up in the comments.
Cheers Andy
Nice idea, unfortunately that won't be possible.
Link thunder can only use fuel or ignition cut with timing retard in order to manage traction. And from my own experience this is more than enough to keep your Supra pointing straight.
Even if you wired the sub throttle motor and sub throttle TPS, you wouldn't be able to directly control them using any of the functions that the Link comes with to achieve what you are after.
You can however use the stock inlet with the sub throttle inactive with no issues though.
