95 RZ-S single turbo auto
mellonman
So after almost 14 years of ownership I’m regrettably putting my much loved Supra up for sale after not being able to get much use out of it. Driving in London means that speedbumps are a constant pain and after having the front lip repaired twice and feeling the pain every time it or the exhaust scrapes, having a work van and a family car. I’ve found myself using it less and less. To this end, I’ve made the decision to let it go to a new owner who'll be able to give it the use it deserves .
It is a 1995 single turbo auto RZ-S with just the right amount of modifications to allow it to perform without going too crazy as per the spec list below. It currently has around 189000 kilometres / miles mix . Dyno power 524bhp with 510ftlb from a T67 dbb @1.3 bar
Engine and turbo spec
- 3.0 2JZ GTE
- Precision T6765 .68ar dbb
- HKS 50mm wastegate
- Japspeed race spec manifold
- HKS intercooler
- apexi adjustable bov
- Siemens 630cc top feed injectors and rail
- Sard fuel pressure regulator
- pulsation dampener bypass
- 3.5 inch turbo back custom exhaust with 2 silences
- walbro 400 fuel pump
- Carbon fiber cam cover
- Catch can and breather setup
Drive train & suspension
- Shimmed stock auto
- Modified torque converter (Stall around 2600rpm)
- Large transmission cooler
- Stock LSD
- OEM big spec brakes
- Uprated front and rear Chriswilson  pads
- Grooved and drilled discs
- Do luck braided brake lines
- Rear strut brace
ECU and electrics
- AEM Fic 8
- Apexi avcr
- AEM afr gauge
- Clifford concept 650 alarm with proximity
Interior
- Retrimed stock seats black and grey with supra logo
- Black and grey TRD style steering wheel
- Electric folding mirrors
- Plazma glow dials
- Dash lamps replaced with LED
The interior is in great condition – considering the age of the car it’s in brilliant condition. The carpet is the black facelift version and also has the black vinyl roof lining it still has the grey pure sports Matt’s.
 In-car Audio
- This car come with the premium sound system and still has the stock sub in the boot and amp under the seat but didn’t get the connector to run it from my new head unit
- 6inch mid range front door speakers
- Kenwood double din stereo with USB
Exterior
- Stock side skirts
- Stock front bumper with bonded whifbitz lip
- 18" Ruff racing wheels.
- Prefacelift head lights with black inserts .
- LED headlights
- Clear indicators
- Modified rear lights with clear lens and LED lamps
- Rear hatch wiper and washer delete
- Stubby aerial
- do-luck rear defuser
The bad bits…
- The ABS, light comes on intermittently.  This started when a earth fault was being found fiddling around behind the kick panel somewhere so probably a quick fix for someone who knows whats what. It hasn’t affected the ABS at all
- Some rust bubbles are coming on rear arches
- Cracked front lip and front bumper could do with a respray
 - valve stem seals could do with being replaced
The good bits...
Have done a full service this year , Timing belt , Water pump , coolant flush, Thermostat , Engine oil , Diff oil .
- The front tyres are both new Goodyears
The car has a great presence with the single turbo complementing the lines of the car makes this a great all rounder. The car really needs to be seen to be appreciated - its 25 years old car and there may be the odd blemish but generally she’s in good condition. I'm sure there is lots I have missed.
Sold
 Price £18,500
Edited by mellonman (see edit history)
  • 1 month later...
