Ollie Posted November 13, 2020 Share Posted November 13, 2020 Hi , I have recently purchased a 220 big case diff for a conversion on my jap spec ttauto . my question is what is the difference between the diffs with the black pipe on the top and not , this is the one i have purchased below . thanks Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted November 13, 2020 Share Posted November 13, 2020 (edited) The connectors on the top would indicate that this came off a Euro / UK spec TT car. The pipes originally connected to a diff cooler system. Given that you won't have the diff cooler on your car you could remove the pipes and block the holes off with some blanking plugs. I've got a UK Spec diff case in my J-Spec car and I've done the same. Edited November 13, 2020 by mwilkinson (see edit history) Quote Link to comment Share on other sites More sharing options...
