Info on big case
Ollie
Hi , I have recently purchased a 220 big case diff for a conversion on my jap spec ttauto .
my question is what is the difference between the diffs with the black pipe on the top and not , this is the one i have purchased  below .
thanks
The connectors on the top would indicate that this came off a Euro / UK spec TT car.  The pipes originally connected to a diff cooler system.
Given that you won't have the diff cooler on your car you could remove the pipes and block the holes off with some blanking plugs.
I've got a UK Spec diff case in my J-Spec car and I've done the same.
Edited by mwilkinson (see edit history)
