Water pump
shaky
A thread on a US site suggested that the water pump should be changed every time the cambelt is changed. I never followed that advice, the car has just had its 5th cambelt fitted and I decided to get the garage to change the water pump and thermostat and idler and tensioner whilst there. All those part were original and frankly they looked good for another 25 years. There is no play in the water pump bearing, like none.
The OE water pump is around £150 and according to the garage a right pain to fit. So expect pushing £250 including fitting at a garage. At least I know my pump was replaced with a Toyota pump and they may not always be available, though I believe the current pumps use plastic vanes and the originals were metal. So I suspect the newer pumps won't age as well as the original.
Garage i use will want the parts ready for fitting because they are busy ,  got no choice but to order one really if they find play in it , i'm going to start collecting parts  now it's getting hard to find oem new parts ,  i'll make sure it has metal fins too ,   and the price i found was £250 for just the pump ?   full cambelt kit come to £310.  anything else i need ??
Toyota are cheap enough for the belt. The rest I sourced elsewhere.
The pump came via TCB for a genuine Toyota. £120+VAT from memory. If Toyota are using plastic fins then you'll have plastic fins if you want OEM. If you aren't bothered about OEM then places like RockAuto sell generics with prices starting from only £12. I just wanted a Toyota part seeing the first pump lasted 24 years with no issues.
  • 2 weeks later...
To further confuse matters, I went with CW’s recommendation and replaced the plastic impeller pump with a metal version.
Give TCB a shout for the best price and also give https://www.rockauto.com/en/catalog/toyota,1995,supra,3.0l+l6+turbocharged,1278626,cooling+system,water+pump,2208 a look. They usually have a 5% voucher floating around on the net, their postage can be a little expensive and you have to factor handling charges and import duties et cetera.
1 hour ago, Frank Bullitt said:
OK did not even know because not used to this new site ,  was still clicking into the old site for a week wondering why it was empty until i found this new one  , :)
Cheers
  • Haha 1
