shaky Posted November 10, 2020 Share Posted November 10, 2020 I will be booking my car in for a service soon, and a new cambelt kit, is the water pump on these cars strong or should i change it ? it's a big price so just needed to know ? Cheers . Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 10, 2020 Share Posted November 10, 2020 Depends how old the current water pump is. If its never been changed then probably worth doing as the cambelt needs to be off anyway. Link to comment Share on other sites More sharing options...
shaky Posted November 10, 2020 Author Share Posted November 10, 2020 Had it 11 years , but done little millage in that time , but yes i'll have to buy one then, lucky i'm in lockdown and not blowing my cash on beer cheers lol Link to comment Share on other sites More sharing options...
rider Posted November 10, 2020 Share Posted November 10, 2020 A thread on a US site suggested that the water pump should be changed every time the cambelt is changed. I never followed that advice, the car has just had its 5th cambelt fitted and I decided to get the garage to change the water pump and thermostat and idler and tensioner whilst there. All those part were original and frankly they looked good for another 25 years. There is no play in the water pump bearing, like none. The OE water pump is around £150 and according to the garage a right pain to fit. So expect pushing £250 including fitting at a garage. At least I know my pump was replaced with a Toyota pump and they may not always be available, though I believe the current pumps use plastic vanes and the originals were metal. So I suspect the newer pumps won't age as well as the original. Link to comment Share on other sites More sharing options...
shaky Posted November 10, 2020 Author Share Posted November 10, 2020 Garage i use will want the parts ready for fitting because they are busy , got no choice but to order one really if they find play in it , i'm going to start collecting parts now it's getting hard to find oem new parts , i'll make sure it has metal fins too , and the price i found was £250 for just the pump ? full cambelt kit come to £310. anything else i need ?? Link to comment Share on other sites More sharing options...
rider Posted November 10, 2020 Share Posted November 10, 2020 Toyota are cheap enough for the belt. The rest I sourced elsewhere. The pump came via TCB for a genuine Toyota. £120+VAT from memory. If Toyota are using plastic fins then you'll have plastic fins if you want OEM. If you aren't bothered about OEM then places like RockAuto sell generics with prices starting from only £12. I just wanted a Toyota part seeing the first pump lasted 24 years with no issues. Link to comment Share on other sites More sharing options...
mattdavies Posted November 11, 2020 Share Posted November 11, 2020 If you search it there is a part number for just the front part of the water pump, the rear half is basically just a casting. Its half the price of the full pump and will require less labour Link to comment Share on other sites More sharing options...
Swampy442 Posted November 11, 2020 Share Posted November 11, 2020 Its up to you really, change it while its right in front of you, or wait until it lets go, strip the front of the engine to get it out and replace it. Know what I'd do. Link to comment Share on other sites More sharing options...
shaky Posted November 11, 2020 Author Share Posted November 11, 2020 Yes i will change it ,did not know it split in two though ? i will call mr T to get a price on that , i've only seen the pump for sale ? not part of it . Link to comment Share on other sites More sharing options...
mattdavies Posted November 11, 2020 Share Posted November 11, 2020 6 minutes ago, shaky said: Yes i will change it ,did not know it split in two though ? i will call mr T to get a price on that , i've only seen the pump for sale ? not part of it . I believe you have to find the Aisin Part number as MR T doesnt sell it in two halves only as a whole Link to comment Share on other sites More sharing options...
shaky Posted November 11, 2020 Author Share Posted November 11, 2020 I'll end up paying for a full one knowing my luck, i have no part number for it , mr T is crap with numbers too Link to comment Share on other sites More sharing options...
mattdavies Posted November 11, 2020 Share Posted November 11, 2020 Aisin # WPT-038 according to this thread: https://www.supraforums.com/threads/replacing-only-front-half-of-water-pump.997641/ Link to comment Share on other sites More sharing options...
mellonman Posted November 11, 2020 Share Posted November 11, 2020 I went with a metal asin one . But the plastic ones have better fine design. If redoing it again I would pick the plastic design Link to comment Share on other sites More sharing options...
mattdavies Posted November 24, 2020 Share Posted November 24, 2020 https://www.amazon.co.uk/Aisin-WPT-038-Engine-Water-Pump/dp/B008EEZ6KS Reading the reviews hear seem to agree with the Supraforums post Link to comment Share on other sites More sharing options...
shaky Posted November 24, 2020 Author Share Posted November 24, 2020 2 hours ago, mattdavies said: https://www.amazon.co.uk/Aisin-WPT-038-Engine-Water-Pump/dp/B008EEZ6KS Reading the reviews hear seem to agree with the Supraforums post That's the price of a supra one ?? put my reg in and my car dose not exist, even mr T says it dose not exist ? Link to comment Share on other sites More sharing options...
keron Posted November 24, 2020 Share Posted November 24, 2020 What engine do you have? na or tt? Link to comment Share on other sites More sharing options...
shaky Posted November 24, 2020 Author Share Posted November 24, 2020 tt 95 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted November 24, 2020 Share Posted November 24, 2020 To further confuse matters, I went with CW’s recommendation and replaced the plastic impeller pump with a metal version. Give TCB a shout for the best price and also give https://www.rockauto.com/en/catalog/toyota,1995,supra,3.0l+l6+turbocharged,1278626,cooling+system,water+pump,2208 a look. They usually have a 5% voucher floating around on the net, their postage can be a little expensive and you have to factor handling charges and import duties et cetera. Link to comment Share on other sites More sharing options...
shaky Posted November 24, 2020 Author Share Posted November 24, 2020 (edited) Have you got a link for TCB ? never seen that company before . cheers for the advice Just found it . Edited November 24, 2020 by shaky (see edit history) 1 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted November 24, 2020 Share Posted November 24, 2020 (edited) They are now a forum trader - https://www.mkivsupra.net/topic/246178-trader-application-tcb-performance-parts-ltd/page/3/?tab=comments#comment-3526128 Edited November 24, 2020 by Frank Bullitt (see edit history) Link to comment Share on other sites More sharing options...
keron Posted November 24, 2020 Share Posted November 24, 2020 ok i have new oem pumps on shelf.... just the pump if needed... Link to comment Share on other sites More sharing options...
shaky Posted November 24, 2020 Author Share Posted November 24, 2020 1 hour ago, Frank Bullitt said: They are now a forum trader - https://www.mkivsupra.net/topic/246178-trader-application-tcb-performance-parts-ltd/page/3/?tab=comments#comment-3526128 OK did not even know because not used to this new site , was still clicking into the old site for a week wondering why it was empty until i found this new one , Cheers 1 Link to comment Share on other sites More sharing options...
mattdavies Posted November 25, 2020 Share Posted November 25, 2020 On 11/24/2020 at 8:18 AM, mattdavies said: https://www.amazon.co.uk/Aisin-WPT-038-Engine-Water-Pump/dp/B008EEZ6KS Reading the reviews hear seem to agree with the Supraforums post Just bought this one for mine, decided it needed doing. Will update when it turns up Link to comment Share on other sites More sharing options...
black_widow87 Posted December 27, 2024 Share Posted December 27, 2024 Thread revival! Is there any feedback on the AISIN WPT-038 as iv just bought one the same one from Amazon.. Link to comment Share on other sites More sharing options...
mattdavies Posted December 30, 2024 Share Posted December 30, 2024 On 12/27/2024 at 4:24 PM, black_widow87 said: Thread revival! Is there any feedback on the AISIN WPT-038 as iv just bought one the same one from Amazon.. Yes, I bought it and it came with the Gasket, its been good since i fitted it shortly after the post above 1 Link to comment Share on other sites More sharing options...
