Mugello Posted November 7, 2020 Share Posted November 7, 2020 Hi all, On big single builds do people retain the idle up valve for the power steering system? I'm debating ordering one as mine is broken. (picture attached). I believe this needs a vac line before and after the throttle body to work? Link to comment Share on other sites More sharing options...
Konrad Posted November 9, 2020 Share Posted November 9, 2020 If it helps, when I installed 1uzfe in mine, i got rid of this valve and just blanked a hole. All is good. Link to comment Share on other sites More sharing options...
Mugello Posted November 10, 2020 Author Share Posted November 10, 2020 On 11/9/2020 at 12:06 PM, Konrad said: If it helps, when I installed 1uzfe in mine, i got rid of this valve and just blanked a hole. All is good. Interesting, I think more people have done this too. Do you have any issues with dry steering vs the engine idle speed? Link to comment Share on other sites More sharing options...
Swampy442 Posted November 11, 2020 Share Posted November 11, 2020 I retained mine, and I believe I have a spare on the shelf Link to comment Share on other sites More sharing options...
Mugello Posted November 13, 2020 Author Share Posted November 13, 2020 On 11/11/2020 at 9:00 AM, Swampy442 said: I retained mine, and I believe I have a spare on the shelf Thanks for the reply, will drop you a PM. Link to comment Share on other sites More sharing options...
Konrad Posted November 14, 2020 Share Posted November 14, 2020 On 11/10/2020 at 8:34 PM, Mugello said: Interesting, I think more people have done this too. Do you have any issues with dry steering vs the engine idle speed? In 1uzfe conversion world most people blank it, saves them trouble with valve failing and spreading oil everywhere. I had no issues or noises when turning wheels when stationary, revs drop down a fraction, but way above stall point. Link to comment Share on other sites More sharing options...
Mugello Posted November 14, 2020 Author Share Posted November 14, 2020 2 minutes ago, Konrad said: In 1uzfe conversion world most people blank it, saves them trouble with valve failing and spreading oil everywhere. I had no issues or noises when turning wheels when stationary, revs drop down a fraction, but way above stall point. Thanks for the reply - Good to know. Do you typically blank it off with a bolt? Link to comment Share on other sites More sharing options...
Konrad Posted November 14, 2020 Share Posted November 14, 2020 (edited) I used old valve, just cut top of it and welded it shut. Below you got youtube video with bolt being used instead of welding. Edited November 14, 2020 by Konrad (see edit history) Link to comment Share on other sites More sharing options...
Konrad Posted November 14, 2020 Share Posted November 14, 2020 Link to comment Share on other sites More sharing options...
Mugello Posted November 15, 2020 Author Share Posted November 15, 2020 Very helpful, thanks Konrad. I will be deleting my idle up valve! Link to comment Share on other sites More sharing options...
