HKS EVC V Electronic Variable Boost Controller
Pete
Anyone looking for a decent boost controller?
Mine is currently very cheap on eBay. Hurry, ends this weekend!
https://www.ebay.co.uk/itm/203163200487
Quality spec boost controller with great stepping motor, 2 boost settings, display screen w/ gauge that shows peak boost, over boost warning, boost scramble mode etc.
Previously used in a Toyota Supra Mk IV
Comes with everything you need / see in the photos.
Specs:
Original blurb from the site:
HKS' all-new EVC (Electronic Valve Controller) is the first boost controller to feature integrated CPUs in each component (Display Unit, Control Module, and Stepping Motor) for more precise control, quicker response and improved boost pressure stability. This race proven system is available in kPa and PSI measurement and features an easy-to-read LCD panel that can be positioned separately from the control module for driver convenience.
Part # 45003-XK001
MSRP: $599.00
Negative Lit LCD
White Foreground / Black Background
Silver Display Case
Silver Control Unit Case
kPa Measurement
High Boost Capability
250kPa/36.25PSI/2.5Bar
Digital and Analog Display
2 Mode Boost Settings
Separate A and B boost levels can be input completely independent from each other
Peak Hold Function
Scramble Boost Function
When the SBC button is depressed a preset boost increase will occur for a preset time (0-40seconds).
Remote Scramble Boost Trigger compatible
Warning Function
Compact Design
Wide Screen Multi-Display
Data Lock Function
A security code can be inputted to protect against accidental changes in settings.
Dimmer Function
Data Memory Function
Stock Boost Return Function
  On 11/11/2020 at 12:11 PM, edviss said:
Pete,
Is this a later version that has Offset option that allows you to manipulate how fast your wastegate opens and closes?
I know you mentioned in the add but just to double check :)
If not sure, you can check on the screen. Video from 11:05
Expand
Glad you checked as I would’ve hated to disappoint. I just wired up this unit to check and it does the same as the guy in the video, no step 7!
