David P Posted July 17, 2020 Share Posted July 17, 2020 I have had my drive extended and it is now 27" longer, which might only be a little, yet is enough to make a big difference. There is now enough space for Socially Distanced fine weather transmission tinkering. Using the back of a van as a bench saves all of the heavy lifting and my little stool is the perfect height to perch on. Lavender smells better than ATF too. Servicing and shimming accumulators on Wile-e Coyote's Tiptronic box Converting an Aristo Tiptronic box to fit Supra, servicing and shimming accumulators for Uzair Link to comment Share on other sites More sharing options...
