David P Posted November 19, 2018 Share Posted November 19, 2018 When using a transmission from an alternative Toyota/Lexus, the 4-different designs of transmission prop-flanges, 3-different sized bell-housings, 2-different sized donuts, 2-different prop centre-joints, 2-different transmission-mounts and several different lengths of vehicles; results with many variables Further to the "recipe" I have used for my own Supra and many N/A-T Supra's, there are other combinations of components when using alternative engines and/or in alternative cars However, most of the owners of these alternative working combinations have little or no idea which components they actually have? Consequently, I can't feed this information to the Prisoner Messaging baby-birds that want-want WANT it I have listed which parts of these combinations that I know of and have requested the remainder, as & when this missing information is identified, volunteered or exposed by common denomination, I'll update it below Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 David P Supra 2JZA80-G(Z)E (Stock OE components only) Bellhousing J3 - Trans-mount boomerang - Box A340E-GTE Hybrid - Flange T.T. auto 4-bolt - Propshaft T.T. auto - Diff AO1B - Diff-flange large-donut. (Alternatively, this recipe can use a T.T. diff instead of swapping the diff-flange.) Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 Rossi Ross Soarer 1JZA80-GTE (Stock OE components only) Bellhousing J3 - Trans-mount boomerang - Box Aristo A34#E-GTE Tiptronic Hybrid - Flange GS300 small-donut - Propshaft V8 Soarer - Diff AO1A - Diff-flange small-donut. Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 J_Meiser Supra 1UZ-FE (Stock OE components only) Bellhousing U1 - Trans-mount boomerang - Box GS300 A343E Hybrid - Flange small-donut - Propshaft front-section V8 Soarer - Propshaft rear-section T.T. auto - Diff AO2B - Diff-flange large donut. Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 Delboy52 Supra 1UZ-FE VVT-i Bellhousing U1 - Trans-mount boomerang - Box A340E-GTE Hybrid - Flange T.T. auto 4-bolt - Propshaft front-section T.T. auto - Propshaft rear-section cut & shortened V8 Soarer - Diff AO2B - Diff-flange small-donut. Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 Paul 887 Supra 1UZ-FE (This 1UZ-FE is from a very early model LS400 and it turns out that many things are different from later LS400's and Soarers, including the engine mounts?) Bellhousing U1 - Trans-mount unknown - Box A341E shimmed - Flange small donut - Propshaft front-section LS400 - Propshaft rear-section cut & shortened V8 Soarer - Diff AO1A - Diff-flange small-donut. (Waiting for pics) Link to comment Share on other sites More sharing options...
David P Posted November 19, 2018 Author Share Posted November 19, 2018 neil-tt Soarer 1JZA80-GTE - sold on to tom_jz Bellhousing J3 - Trans-mount boomerang - Box A340E-GTE Hybrid - Flange T.T. auto 4-bolt - Propshaft front-section T.T. auto - Propshaft rear-section cut & shortened LS430 - Diff AO2B - Diff-flange large-donut. Link to comment Share on other sites More sharing options...
David P Posted November 20, 2018 Author Share Posted November 20, 2018 Aristo transmission is an OE components plug & play fit into T.T. Supra by using; Lexus SC430 prop front-section and T.T. auto prop rear-section. Alternatively (and my preference), swap the Aristo prop-flange for a T.T. auto prop-flange as explained here. http://www.mkivsupra.net/vbb/group.php?discussionid=223&do=discuss Link to comment Share on other sites More sharing options...
David P Posted November 22, 2018 Author Share Posted November 22, 2018 [video=youtube;cXa-5GGdyz4]https://youtube;com/watch?v=cXa-5GGdyz4 Link to comment Share on other sites More sharing options...
David P Posted November 26, 2018 Author Share Posted November 26, 2018 Squeaky's wrestled and baby birds (that can read and maintain focus for a few short sentences) now fed. Link to comment Share on other sites More sharing options...
David P Posted July 14, 2020 Author Share Posted July 14, 2020 Note: The spacers that are behind the centre-bearing carrier are size matched to the shell of the car. Whatever prop-swappery, use the spacers that come with the shell and not any others that might have come with a prop. Link to comment Share on other sites More sharing options...
