mark.supra Posted October 10, 2005 Share Posted October 10, 2005 Just wondered when you should change the cam belt to be safe. My baby is showing 42000 miles. Also how much would i expect to pay? Link to comment Share on other sites More sharing options...
Paul Posted October 10, 2005 Share Posted October 10, 2005 62000 or five years I believe? Just had mine changed at 80,000 despite it having one at 60,000 only becuase the five years was up. Paul Link to comment Share on other sites More sharing options...
supragold Posted October 10, 2005 Share Posted October 10, 2005 I paid about £175 for my cam belt change with a Toyota dealer about 1 1/2 years ago. Link to comment Share on other sites More sharing options...
rob wild Posted October 10, 2005 Share Posted October 10, 2005 The maintenance Schedule says 60K but i had mine done at 45K cause it was starting to look shabby. I paid £145 from a local garage. Here's the maintenance Schedule: http://www.mkiv.com/manual/manualtt/maintenance_schedule/a.jpg Link to comment Share on other sites More sharing options...
bignum Posted October 10, 2005 Share Posted October 10, 2005 hi matey,the book says 60k but i got mine done at 50,ive heard of some going just before 60k and its not pretty,expect to pay around the 200 mark using a toyota belt NOT some car spares crap,also dont scrimp on the fitting,the first "garage"i took mine too took 4 hours and couldent undo the crank bolt,next specialist i went too ,job completed in 2 hours so spend that little extraits worth the piece of mind. Link to comment Share on other sites More sharing options...
Homer Posted October 10, 2005 Share Posted October 10, 2005 As Paul said its 60k or 5 yrs, any pre 95 supra should be on at least its 3rd belt by now. So, if you think your's hasn't been changed since 2000 then its due soon! Link to comment Share on other sites More sharing options...
Digsy Posted October 10, 2005 Share Posted October 10, 2005 Its not a bad idea to change the belt when you buy the car so you know where you are starting from. As for it being "not pretty" if the cambelt goes, all Supras apart from VVTIs are clearance engines, so the worst that will happen is an embarrasing tow home. Link to comment Share on other sites More sharing options...
merckx Posted October 10, 2005 Share Posted October 10, 2005 all Supras apart from VVTIs are clearance engines Never knew that, are you 100% sure? Link to comment Share on other sites More sharing options...
Digsy Posted October 10, 2005 Share Posted October 10, 2005 Yep, its been discussed on here several times before. Actually, if you run big cams or buy vernier pulleys and feck about with the timing then you can make the engine into an interference one. Someone may post up the limit on cam duration if they read this. Link to comment Share on other sites More sharing options...
merckx Posted October 10, 2005 Share Posted October 10, 2005 Yep, its been discussed on here several times before. I better get the new belt I've got fitted then! Link to comment Share on other sites More sharing options...
Scarface GTti Posted October 10, 2005 Share Posted October 10, 2005 My mate had a Nissan Micra and he read the manual as saying change the belt at 50k. So seeing as he was on 48k he had some time to go. Unfortunately it was 50k or every 3 years. One day when the car was idling on the drive the 13 year old cambelt let go! When i pulled the engine down the cambelt had crumbled to a dust type of compound and it had wiped out 3 valves. I should think that hardly anyone on here does the type of mileage to warrant what mileage its due, i would concentrate more upon the amount of time it has been on. If you don`t know, change it now! It was the very first job i did on mine. Link to comment Share on other sites More sharing options...
SimonB Posted October 10, 2005 Share Posted October 10, 2005 It's 6 years actually, not 5. Link to comment Share on other sites More sharing options...
Markie Posted October 10, 2005 Share Posted October 10, 2005 Its not a bad idea to change the belt when you buy the car so you know where you are starting from. As for it being "not pretty" if the cambelt goes, all Supras apart from VVTIs are clearance engines, so the worst that will happen is an embarrasing tow home. Thought I had read on here that all the Supra Engines are clearance engines? God damn.. Got any links to threads incase I cant find them.. Going to loo around now. Link to comment Share on other sites More sharing options...
CJ Posted October 10, 2005 Share Posted October 10, 2005 Well, mine is definitely non interference...as I found out 2 weeks ago on the M4 in the pissing down rain Link to comment Share on other sites More sharing options...
Jake Posted October 10, 2005 Share Posted October 10, 2005 Originally Posted by Digsy if the cambelt goes, all Supras apart from VVTIs are clearance engines, Thought I had read on here that all the Supra Engines are clearance engines? All apart from the NA VVTi. And you'll be hard pushed find one of those rare beasts in the UK Link to comment Share on other sites More sharing options...
supRo Posted October 10, 2005 Share Posted October 10, 2005 For BPU/small single, are stock belts adequate or kevlar/uprated belt essential? Link to comment Share on other sites More sharing options...
Markie Posted October 10, 2005 Share Posted October 10, 2005 All apart from the NA VVTi. And you'll be hard pushed find one of those rare beasts in the UK Erm, does that mean the TT VVT-i is non-interferance then? Link to comment Share on other sites More sharing options...
CJ Posted October 10, 2005 Share Posted October 10, 2005 Erm, does that mean the TT VVT-i is non-interferance then? Yes Link to comment Share on other sites More sharing options...
Jake Posted October 10, 2005 Share Posted October 10, 2005 Erm, does that mean the TT VVT-i is non-interferance then? Yes Link to comment Share on other sites More sharing options...
mark.supra Posted October 11, 2005 Author Share Posted October 11, 2005 Thanks everyone,helpful as ever....CHEERS Link to comment Share on other sites More sharing options...
max55uk Posted October 13, 2005 Share Posted October 13, 2005 If there is no record of the cambelt being replaced get it sorted for the sake of 150 pounds!, specially Jap imports, they boast very low mileage but can be decieving!. Link to comment Share on other sites More sharing options...
