David P Posted February 8, 2018 Share Posted February 8, 2018 Courtesy of Delboy52 I.D. pics, pin-outs and part numbers for loom clips on N/A, T.T. and Tiptronic Supra Transmissions. Link to comment Share on other sites More sharing options...
Delboy52 Posted February 8, 2018 Share Posted February 8, 2018 - 2JZ-GE (NA) A340E 4 speed ECT pinout with connector plug part number - 90980-10919 - 2JZ-GTE (TT) A343E 4 speed ECT pinout with connector plug part number - 90980-11190 - 2JZ-GTE VVT-i (TT) A343E 4 speed tiptronic ECT pinout with connector plug part number - 90980-11151 Link to comment Share on other sites More sharing options...
Delboy52 Posted February 25, 2018 Share Posted February 25, 2018 - 2JZ-GE/GTE (NA & TT) No.2 Speed Sensor & O/D Clutch sensor connector part number - 90980-11156 O/D clutch sensor is at the front nearer to bell housing, No.2 speed sensor is towards the back near the solenoid connector. - 2JZ-GTE (TT) No.1 Speed Sensor connector part number - 90980-11143 - 2JZ-GE/GTE (NA & TT) Neutral Start switch connector part number - 90980-11332 - 2JZ-GE/GTE (NA & TT) A/T Temperature sensor connector part number - 90980-11025 / 90980-11401 There are two part numbers and either one can be used. Link to comment Share on other sites More sharing options...
zedhex Posted February 14, 2019 Share Posted February 14, 2019 Does anyone know part number for the neutral park switch connector for the soarer A340 box? It's not the same as the one in the Supra. Here is the Soarer one: https://www.dropbox.com/s/7e3bi80tkt06khs/20190212_163556.jpg?dl=0 Link to comment Share on other sites More sharing options...
Delboy52 Posted February 15, 2019 Share Posted February 15, 2019 The start switch is 84540-50010: SWITCH & RELAY & COMPUTER Japan - 05/1991-11/2000 - TOYOTA SOARER - JZZ3*,UZZ3* The connector looks to be a 9P Waterproof Type: 90980–11643 Example: https://www.drive2.ru/c/493768957753295150/ Link to comment Share on other sites More sharing options...
zedhex Posted February 17, 2019 Share Posted February 17, 2019 Thanks Mike - that should sort things out Link to comment Share on other sites More sharing options...
zedhex Posted February 28, 2019 Share Posted February 28, 2019 The neutral start switch on the soarer box is part number 84540-50010 It's also used on the following UK models: 12/1989-09/1994 LEXUS LS400 UCF10 08/1988-07/1997 TOYOTA HILUX RN1**,YN85,90,1**,LN85,90,1**,VZN130,KZN130 Neutral start switch on the tipTronic box is part number 84540-30320 It's also used on the following UK models: 01/1999-06/2005 LEXUS IS200/300 GXE10,JCE10 08/1997-12/2004 LEXUS GS300/430 JZS160,UZS161 01/2005-11/2011 LEXUS GS30, TOYOTA 35, 43, 460 GRS19*,URS190,UZS190 11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* I feel a trip to the nearest breakers yard is coming on... Link to comment Share on other sites More sharing options...
David P Posted March 11, 2019 Author Share Posted March 11, 2019 To locate any of the loom plugs above, just Google search the part numbers and there you will find several options. Watch out for rip off postage prices from USA sourced items and note that you also have to pay import taxes on the shipping cost. Link to comment Share on other sites More sharing options...
