David P Posted December 7, 2017 Share Posted December 7, 2017 Using the front prop-section from a Soarer, the GS300 A343E box is a plug & play fit into T.T. Supra. Or if you prefer, alternatively, you could cut off the tail shaft protrusion, fit a T.T. prop flange and use the T.T. prop as is. How to here. http://www.mkivsupra.net/vbb/group.php?discussionid=223&do=discuss Note that you will need to replace the GS300's J2 bell-housing with the J3 bell-housing from a T.T. Supra, which allows fit of the stronger T.T. Supra torque-converter. Thank you for the prop info J_Meiser Link to comment Share on other sites More sharing options...
