David P Posted May 22, 2017 Share Posted May 22, 2017 Remove Aristo/GS300 prop-flange, cut off tail-shaft protrusion, fit Supra prop-flange. (Which is why I try and save T.T. auto transmission prop-flanges from the skip here.) (In attempt to recycle them towards Members Projects here.) (Please don't skip the Aristo transmission prop-flange, why here.) FYI. Supra T.T. YOKE ASSY, FLANGE part no. 34780-14020. Mr T's. price: £110? Guesstimate Link to comment Share on other sites More sharing options...
David P Posted May 24, 2017 Author Share Posted May 24, 2017 A340E Aristo transmission has 3-hole size 'B' donut prop-flange A650E with same as Aristo Flange - showing prop-donut-locating protrusion that needs cutting off using an angle grinder with a slitting disc. Link to comment Share on other sites More sharing options...
David P Posted May 24, 2017 Author Share Posted May 24, 2017 A650E transmission with same as Aristo size 'B' donut flange - here without donut - showing protrusion that requires amputation (pic Delboy52 ) Supra T.T. transmission 4-stud flange - No protrusion for prop location required Link to comment Share on other sites More sharing options...
David P Posted May 29, 2017 Author Share Posted May 29, 2017 If/when this conversion has/is documented in a thread? Please send me a link and I'll post it here for further reference. Link to comment Share on other sites More sharing options...
David P Posted November 20, 2017 Author Share Posted November 20, 2017 Put gear selector into position P, open lock tab and remove flange-nut, an air spanner may well be necessary to undo this nut. Wrap a cloth around tail-shaft end to prevent ingress of foreign debris, then cut off protruding centre pin with angle grinder fitted with a 1mm slitting disc. I recommend that you clean the splines inside flange and on tail shaft with brake cleaner and assemble with RTV on the inside of flange splines ONLY. This prevents ATF leaking through/past 20 years old splines. Fit Supra rear flange and torque the nut up to 90 ft-lb. If the transmission has a different breather, swap for Supra version. The Aristo box is now a plug & play fit into Supra. Link to comment Share on other sites More sharing options...
David P Posted November 20, 2017 Author Share Posted November 20, 2017 This simple fact confusticates many idiots! In a dipsticks nutshell; The A340E Aristo box is the same F box as an A340E J spec Supra, except it has a different F prop-flange and sometimes a different F breather. Same for GS300 A343E, which is same box as U.K. spec Supra. (Note: GS300 box has a size "A" donut flange, which means that a Soarer prop-shaft front-section can be used as an alternative way to achieve a plug & play T.T. Supra fit.) If you can't understand that, then please go away and spend lots of money instead. Link to comment Share on other sites More sharing options...
David P Posted March 5, 2018 Author Share Posted March 5, 2018 Despite all of my begging, so far not a single person has yet saved me a Supra transmission prop-flange from a dead box. Maybe one day, someone could explain why Club Members have this fascination to throw their money into a skip? Link to comment Share on other sites More sharing options...
David P Posted April 1, 2018 Author Share Posted April 1, 2018 Aristo has 3.625:1 diff-ratio & T.T. Auto Supra has 3.769:1 diff-ratio. This graduated little difference will be sent to the ECU from no. 2 speed-sensor, resulting with gear-changes happening up-to 100rpm earlier @ WOT. (If I hadn't told you, you would never have noticed!) If you must, the fix is to remove Aristo tail-shaft housing and swap-in the 3.769:1 Supra T.T. drive-gears into no. 2 speed-sensor. These gears are in matching pairs and MUST be kept in matching pairs. Opposite example; fitting 4.083 N/A gears into 3.769:1 T.T. auto box with N/A ECU transmission control gives 200 rpm higher gear-changes. http://www.mkivsupra.net/vbb/group.php?discussionid=229&do=discuss Link to comment Share on other sites More sharing options...
David P Posted July 14, 2020 Author Share Posted July 14, 2020 Part number for transmission-flange to prop-shaft nuts 90179-11017 x 4 should be around £2.50 each? Link to comment Share on other sites More sharing options...
David P Posted July 15, 2020 Author Share Posted July 15, 2020 Unlock tab on nut with centre punch and hammer, then put box into P and undo with 30mm deep socket. Pull off Aristo flange and seal off gaping hole with tape. Link to comment Share on other sites More sharing options...
David P Posted July 15, 2020 Author Share Posted July 15, 2020 Using an angle grinder, cut off centre peg. Make sure that the 2 shims are between the flange and transmission fit Supra flange, re-tighten nut to 90ftlb and re-lock tab on nut with hammer and punch. (The Eagle Eyed may notice that the tab on this nut is yet to be locked.) Link to comment Share on other sites More sharing options...
wile e coyote Posted July 15, 2020 Share Posted July 15, 2020 Nice to see my flange has a new home Link to comment Share on other sites More sharing options...
David P Posted July 16, 2020 Author Share Posted July 16, 2020 One final detail: Some Aristo boxes have a hose from the "breather" at the top, yet Supra boxes have a neat little "capped breather". Using pliers, these will simply pull out and are easily swapped. Link to comment Share on other sites More sharing options...
